5.1 speakers to go with Polk RTi A5s? - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2013, 01:59 PM - Thread Starter
RRenton's Avatar
I'm looking at Polk speakers. I know I'm getting RTi A5s for my front speakers for sure. I'm not necessarily going for something loud, I just want great sound quality. I'm wondering if for my center speaker I should get the CSi A6 or save a bit of money and get the CSi A4. Would the RTi A5 overpower a CSi A4?
Also, for my surrounds, I'm trying to decide between a pair of FXi A4s or FXi A6s. I'm leaning towards A4 because I think the A6s would be too bulky for where I want to put them, but would the A4s get overpowered?
My receiver can set the dB level of each speaker, could I just decrease it on the A5s and increase it on the smaller speakers to balance them out?
By the way, I have a Pioneer VSX-522-K. I may upgrade someday, but I probably won't if I don't have to. As far as I know the only thing that really appeals to me from upgrading is more HDMI ports and component ports.
RRenton is offline
Old 05-07-2013, 08:23 PM
basshead81's Avatar
Quoted: 181 Post(s)
Liked: 5302
i run the csi a4 with rti a7's...my yamaha 773 does not add any gain to the center when i run ypao calibration. Kim Jasper at polk audio told me it was a good match. he only recomended the csi a6 with very large rooms and a9 speakers.
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
