Combine Two Sources by Twisting Speaker Wires Together? - AVS Forum | Home Theater Discussions And Reviews
Old 05-07-2013, 11:35 PM - Thread Starter
prnoct90's Avatar
I know if you want to turn a stereo source into a mono one, you can twist the l and r cables together before they enter the speakers, but I have another question. I have a very complicated setup that I am trying to do, and I wont go into all of it now. I am trying to make it all as automatic and seamless as possible.
My question is, if I have two different sources (receiver/amp), and I twist the right cables from both sources together and hook them both up to the right speaker, and then I twist the left speaker cables together and connect both to the left speaker, what will happen?
My desired result it this, I would never be using both sources at once, but I want the speakers to work automatically with either source.
prnoct90 is offline
Old 05-08-2013, 06:16 AM
Bill Fitzmaurice's Avatar
Liked: 4632
You will be taking a trip to the store to replace all the gear that you fried. mad.gif
Bill Fitzmaurice is online now
Old 05-08-2013, 07:37 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
You need to buy a speaker switch, which will let you switch the speakers to the amplifier/receiver that you want to use.
And do the switching with both amplifiers/receivers TURNED OFF.
Doing what you proposed will damage the equipment.
commsysman is offline
