Couple questions regarding the Bowers & Wilkins 805 speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-08-2013, 07:09 AM - Thread Starter
ckett's Avatar
I am considering the Bowers and Wilkins 805 speakers as part of a home theater/music room.
How much better are the 805Ds as compared to the 805S?
Would the 805S be a better speaker than the CM5 bookshelf?
In terms of a center speaker, would the CM Centre 2 match well with the 805D or should I stick with the 800 series center for a closer matching tweeter?
ckett is offline
post #2 of 2 Old 05-08-2013, 05:36 PM
Brian B's Avatar
Quoted: 235 Post(s)
Liked: 104
You'll probably get more replies in the dedicated B&W thread...but.
805D vs. 805S--significantly better.
Yes, 805S would be better than the CM5.
CM does not match 800 series. Drivers, config, cabinet, crossovers--all different.
B.
Brian B is offline
Reply Speakers
