Budget Sub woofer for Polk LSI home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 05-08-2013, 10:18 AM - Thread Starter
peerguy's Avatar
First of all Thanks for all the comments, critics and suggestions for helping me purchase a Polk LSI Home theater.
Front: Polk LSI15.
Center: Polk LSI C
Surround: Polk LSI 7
Receiver: Pioneer SC-1522
Amplifier: Used Parasound HCA-1200 ii. (300 watts per channel at 4 ohms).
I started out with a budget of $800 and far exceeded it with the LSI series. They produce true, clear sound. As mentioned by others the sound imaging is unbelievable. But the LSI15s lack low end Bass. I can tell while watching movies where the bass wasn't just enough.
So I'm looking for a Budget SubWoofer. Can we stick to budget atleast here please?
1) BIC America F12 - $197 on Amazon.
2) Polk PSW505 - $235 on Amazon.
3) Please suggest ..
So what do you think? I have a strict cutoff at @250 since I went over board on my speaker and receiver budget by more than $1500.
Call me El Cheapo. But suggest some good Sub Woofers which are on sale to go with the LSI home theater. My pick is BIC F12 since it can go down to 20 Hz. Suggestions?
Thanks - this forum rocks!
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
AVR: Pioneer SC-1522
Amplifier: Parasound HCA 1200 ii
peerguy is offline
post #2 of 26 Old 05-08-2013, 10:29 AM
newavsmember's Avatar
The budget Sub that get recommended around here is Klipsch RW-12D which is on sale now at newegg for 280( little above your budget). I own this and so far have liked it.
newavsmember is offline
post #3 of 26 Old 05-08-2013, 10:58 AM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
Spring for a little more $ and go with the Klipsch RW-12D. It is usually available from NewEgg for $280-$300.
crn3371 is offline
post #4 of 26 Old 05-08-2013, 11:20 AM
Elihawk's Avatar
Quoted: 1019 Post(s)
Liked: 869
Klipsch also has a 10 inch sub, the synergy, which would be better than alot of options and when I bought the synergy, it was right around 160 dollars!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is offline
post #5 of 26 Old 05-08-2013, 11:58 AM - Thread Starter
peerguy's Avatar
I posted the question on another AV Receiver thread I started and received the same response. Klipsch RW-12D.
looks like the klipsch is winning votes unianimously. I wonder why.. I saw some online forums report Port Chuffing at high volumes on the Klipsch. Can you please explain why you would pick the Klipsch RW-12D over the Bic America F12 which is retailin for less than $200 on Amazon?
I've checked AVS Forums for the comparison and they all point to the Klipsch over the F12. Is it because of more decibels at low frequency? or Build quality? Or glass shattering Bass? I'll go audtion at a local store today if they have it.
On another note: How the hell does Best buy or any other local store compete with NewEgg and Amazon? Local stores have become audition centers and we go online to buy. LOL.
Peerguy (striving to build a budget system and threw the word BUDGET into the trashcan)
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
post #6 of 26 Old 05-08-2013, 12:11 PM
XStanleyX's Avatar
Liked: 1269
It won't have any port chuffing if you don't run it too hot trying to make it do more than it's capable of. For $280 it's as good as you're going to get IMO. I've owned both the 505 and RW-12D in the past and the Klipsch is very clearly the better sub. You won't find the RW-12D at BB and trying to audition a sub in a space that large would be pointless. The RW12D would definitely be my choice. Depending on your room size you may want to add a 2nd one later down the road.
You'll find a budget subwoofer thread in the Sub forum if you look for it.
XStanleyX is offline
post #7 of 26 Old 05-08-2013, 12:58 PM - Thread Starter
peerguy's Avatar
You know what I trust this forum. I bought the Klipsch RW-12D on New Egg. Now for the tough part. The only way I can get this to enter the house is if I can justify using it as some table top. My GF will not let this in as I've already convinced her about the LSI home theater with great difficulty.
So is it ok to use this sub as a table top? to put books, pens, other non electronic stuff? I want to tuck this thing away with a table cloth on top (not on the front and sides) and not make it evident that its a Sub. confused.gif
I've put this together with a long term view to fit into a bigger home in 2-3 years. For now god help thy neighbors next door, upstairs and downsairs apartments. AMEN!
Front: Polk LSI15.
Center: Polk LSI C
Sub Woofer: Klipsch RW-12D
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
post #8 of 26 Old 05-08-2013, 01:12 PM
XStanleyX's Avatar
Liked: 1269
Front: Polk LSI15.
Center: Polk LSI C
Sure, you can put a table cloth on top with other things on top of that. Being in an apt. you'll most likely have to keep the sub level down till you move and let her loose after that. Those low frequencies will travel though those walls like a knife through butter.
post #9 of 26 Old 05-08-2013, 01:25 PM - Thread Starter
peerguy's Avatar
Question:
Klipsch RW-12D can handle low's till 20Hz. LSI 15's can handle I think 50Hz and above. so would it be good to set cross over at 50 Hz on the receiver? Correct me if I got the concept of crossover wrong..
Peerguy
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
post #10 of 26 Old 05-08-2013, 01:38 PM
XStanleyX's Avatar
Liked: 1269
Question:
Peerguy
I used to run the LSi15's with a RW-12D with the crossover set to 80Hz for the sub and speakers. Just set them to what sounds best to your ears. Doesn't hurt to play with the settings.
post #11 of 26 Old 05-08-2013, 07:19 PM
Elihawk's Avatar
Liked: 869
Usually you want a small amount of overlap in your crossover...so if your tower can get down to 50 hz, then I would recommend crossing over at 60-70hz. But as suggested, try multiple cross over points and see what sounds best!
Elihawk is offline
post #12 of 26 Old 05-08-2013, 09:16 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
To echo what everyone else has said, the Klipsch has better SQ, better low frequency extension, and better max output. All around, a better sub. And if you want better quality than that, you'll have to spend $600 to $800 and get a big sub from one of the Internet sub vendors: HSU, Outlaw Audio, SVS, Rythmik Audio, or Power Sound Audio.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #13 of 26 Old 05-08-2013, 09:20 PM
cel4145's Avatar
Liked: 2991
Agreed. A lot of times you'll hear people recommend 80hz as a crossover. But lower is fine if it it sounds better to you given your speakers have pretty low extension.
post #14 of 26 Old 05-09-2013, 11:22 AM
jubei951's Avatar
Quoted: 18 Post(s)
Nice, I was in a similar position
Polk LSi 25
Pioneer SC-1522 K (no external amp tho)
The subs with the LSi's seem pretty decent after I had tweaked them but still wanted better bass. Was set on the BIC F12 until I compared it to the spec and price difference to the Klipsch. I am waiting for my Klipsch RW-12D from Newegg. I haven't personally listened to these subs so it's all based on information found on the forums & online. **Fingers crossed** Lemme know about your experience with the sub and blending in with the Lsi's.
jubei951 is offline
post #15 of 26 Old 05-10-2013, 08:23 AM - Thread Starter
peerguy's Avatar
Polk LSi 25
In the past 2 months:
1) Auditioned the Polk PSW 110 - Purchased for $89 on Amazon. I thought it was a waste of $89. Returned it.
2) Auditioned the Polk PSW 505 - Purchased on Amazon for sale aroud $200. Decent sub. But I was not happy. Returned it.
3) Was deciding between the BIC F12 and Klipsch RW-12D. With the help of this forum I got the Klipsch from Newegg. Plugged it on yesterday. Played the 'Dolby DTS Jurassic' on Youtube. My dog started barking at the sub everytime the T-Rex walked. Obviously my dog ran away when the T-Rex roared. Its that good. I'm keeping it!!
As for the Bic F12 - I'll never know.
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
post #16 of 26 Old 05-10-2013, 08:40 AM
LastButNotLeast's Avatar
Quoted: 1490 Post(s)
Liked: 1090
I was able to get it to chuff (strange sound, that). The demo scene from Pulse did it. At no other time have I had the slightest trouble (you will read reports of loose ports, which is an easy fix). Very highly recommended, especially at the new low, which seems to be $280. And you can use ebates.com for 1% back. Close enough? smile.gif
Michael
peerguy likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #17 of 26 Old 05-10-2013, 09:51 AM
Nethawk's Avatar
Liked: 118
Do yourself a favor and save up for something better than a budget sub. The LSI are excellent speakers, and you have a very decent setup. The compromise will not make you content, IMO.
Nethawk is offline
post #18 of 26 Old 05-10-2013, 11:15 AM
RastaManMax's Avatar
Yeah, spring for the RW-12D for $30-$50 more. Eat KD for lunch for a few weeks if you have to.
I got the 505 for my uncle recently, it does sound really good for the price I paid but the 12D is really awesome for the price.
RastaManMax is offline
post #19 of 26 Old 05-10-2013, 12:21 PM
Liked: 1090
I think Nethawk means "better" as in SVS, HSU, etc.
The point is the Klipsch isn't really a "budget" sub. It's been discontinued (for a while, actually) and is available for a great price.
And when the OP is ready for another sub, the 12d will probably still be good as a second (I have two, my 12d is the newer and better of the two).
post #20 of 26 Old 05-11-2013, 10:15 PM
This^. You'll be shocked at how far that $280 went when you hook it up. Your jaw will also drop when you see the size of the box it comes in. My gf wanted to kill me when she saw the outer box size. After I opened up the outer box, the knife to the neck turned into a solid slap.
post #21 of 26 Old 05-12-2013, 01:49 AM - Thread Starter
peerguy's Avatar
Ha ha. Same story here. We were shocked at the size of the sub. I constantly kept saying I'll use it as a table top to store her books and pens and all non electronic stuff. Sigh! However we watched Titanic and were blown away.
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
post #22 of 26 Old 05-26-2013, 02:30 PM - Thread Starter
peerguy's Avatar
Alright .. Here's a twist. I'm looking to mod the lsi 15's inbuilt sub. Technically the inbuilt sub can't go below 50hz. I'm looking for a mod to make it go as low as 30 or even 20 hz with a quick response.
Any ideas? Did anyone do this?
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
post #23 of 26 Old 05-26-2013, 02:51 PM
Cvetan1's Avatar
Quoted: 35 Post(s)
Liked: 50
I'm sure the response of the built in sub is limited with the combination of the sub itself and the crossover. Requires more work than what its worth. Your best bet, get a good quality sub and cross the LSi's to 80hz as recommended already. Leave the speakers stock, IMO.
Cvetan1 is offline
post #24 of 26 Old 10-18-2013, 07:03 AM - Thread Starter
peerguy's Avatar
Thanks Nethawk and Cvetan1. I followed your advise.
I purchased a PSA XV15 yesterday. Researched for 2 months and finally picked PSA xv15 from a pool of HSU, Rythmik, SVS, PSA, Outlaw, and Epik.
Price point, 15" driver, low frequency extension (upto 16hz) warranty, Tom's support on the forums and user reviews helped make the decision. I'm sure it'll be a good upgrade over the klipsch rw-12d.
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
post #25 of 26 Old 10-18-2013, 11:26 AM
jontyrees's Avatar
Liked: 38
Hah! did you trade in your GF on the new sub? what did you do with the Klipsch?
jontyrees is offline
post #26 of 26 Old 10-18-2013, 05:19 PM - Thread Starter
peerguy's Avatar
I sold it to my cousin. He was impressed with the sub for the price. Worked out well for me!
My Budget system:
Front: Polk LSI15
Center: Polk LSIC
Sub: PSA XV15
peerguy is offline
Reply Speakers
