Computer Speaker Upgrade: Claro Plus+ Card with Klipsch ProMedia 2.1 Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-10-2013, 01:36 PM - Thread Starter
Gyrotica's Avatar
Hello, folks! I am in a bit of a conundrum and I was wondering if anyone could help.
I'm interested in upgrading my current computer speaker setup. I am currently enjoying some Promedia speakers and I'm processing sound through a Plus+ soundcard.
If possible, I'd like to upgrade to 5.1 sound while keeping my 2.1 speakers, but I'm not sure what the optimal way to go about doing so would be. It's possible that it might make more sense to just pick up a whole 5.1 computer speaker package, but I don't know if it will sound quite as good as my Klipsch. Any suggestions on what a good course of action would be, preferably keeping the price of upgrade or replacement at around 200 or 300$?
Gyrotica is offline
post #2 of 3 Old 05-12-2013, 12:31 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
That won't be easy to do since the 2.1 system gets its power from the subwoofer module. You'd have to either go with a passive speaker pack with a receiver or spend a premium on active monitors. I don't think you will get anything decent for $300. Cheapest would be the Energy Take 5.0 speaker package plus a refurbished receiver for maybe $350 to $400 and use the existing ProMedia subwoofer. Klipsch does have their HD Theater speaker packages starting at $400.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #3 of 3 Old 05-12-2013, 12:35 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
caloyzki is offline
Reply Speakers
