In ceiling speakers - what are the best? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-10-2013, 03:07 PM - Thread Starter
LennartzHT's Avatar
Everyone,
I have been juggling the idea of mixing my speaker brands. I am using Focal 700 series for the front, center and sub, but am not sure their in ceiling speakers would do the job. Someone told me I should use an in ceiling speaker that can be directed at the primary audience. Therefore, it looks like I will need a different brand speaker to achieve this. Does anyone have a recommendation? I do not want to spend more than $1500 for the pair.
Thanks all!
LennartzHT
LennartzHT is offline
post #2 of 6 Old 05-10-2013, 03:35 PM - Thread Starter
LennartzHT's Avatar
BTW the focal in-ceiling surrounds are Chorus IC 706 V.
~LennartzHT
post #3 of 6 Old 05-11-2013, 12:14 AM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
You are looking to use in-ceiling speakers for the fronts? Or rears? Or...?
ifor is offline
post #4 of 6 Old 05-11-2013, 09:15 AM - Thread Starter
LennartzHT's Avatar
Hello ifor,
I would be using the in-ceiling speakers for surround in directly behind and to the side of the primary viewing position (see attached floor plan) Home Theater Version.png 210k .png file .
~LennartzHT
Name:	Home Theater Version.png
post #5 of 6 Old 05-11-2013, 02:36 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Is there a room above? If you are happy with the Focal Chorus line, I am inclined to tell you to stick with their in-ceiling model. That said, they are not an enclosed speaker and they have an open baffle design. If there is a bedroom or other living area above this space you will get bleed through from the speakers without an enclosure and some insulation in your ceiling. If you do have living space above, there are some enclosed speaker options out there in your price range that will work. Likewise, I would check to see if Focal sells an enclosure for the speaker you referenced above. Some audio companies sell a separate enclosure for their open baffle models.
ack_bk is offline
post #6 of 6 Old 05-11-2013, 02:38 PM
ifor's Avatar
Quoted: 59 Post(s)
Liked: 72
Spread them a further out and back a couple of feet in both directions and you will be more than fine with the Focal in-ceiling speakers.
No need for directional's when using them as rears.
*note: If you're worried about the open back, look at the Dynabox from Dynamat.
ifor is offline
Reply Speakers
