Need a LCR setup - AVS Forum | Home Theater Discussions And Reviews
Old 05-12-2013, 10:17 AM - Thread Starter
SubaruB4's Avatar
Quoted: 31 Post(s)
Liked: 30
So I was going to start with the center first.. I was looking at these two here
BIC America FH6-LCR Or DV-62CLRS now the first one from what I hear is horn loaded, however a dome would be better off since you don't have to sit within the center line of the speaker.
I'm more leaning to the DV-62CLRS but I'm not sure what to use for the L & R are the DV62si bookshelfs good or should I find something else that would match close with the center?
SubaruB4 is offline
Old 05-12-2013, 10:32 AM
commsysman's Avatar
Quoted: 971 Post(s)
Liked: 523
Horn speakers are not most people's cup of tea when it comes to the sound quality, unless you get into some rather expensive ones.
I suggest that you get some L/R speakers and add the center later, if that is where you are going.
For $349 you can get a pair of Whafedale Diamond 10.1 speakers, which are excellent.
For about $150 you can get a pair of Polk R150 speakers, which are OK for the money.
commsysman is offline
