smaller speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 05-13-2013, 02:17 PM - Thread Starter
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
Looking to replace my old home theater speakers. I would like some decent speakers that aren't huge, I prefer the the look of smaller speakers in my setup. Any recommendations for some smaller wall mountable speakers? Not looking for the best speakers in the world, just best bang for the buck kind of quality.
bassage is offline
post #2 of 10 Old 05-13-2013, 02:20 PM
Louquid's Avatar
Liked: 38
What do you consider small? And do you have a budget?
Louquid is offline
post #3 of 10 Old 05-13-2013, 02:28 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Also your room size, and how far seating is from the front speakers would be helpful.
sdg4vfx is offline
post #4 of 10 Old 05-13-2013, 02:32 PM - Thread Starter
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
Small, I guess would be something no more than 18 inches across. Would like to keep the price at less than $100 per speaker, not counting the sub. I know that's low as far as speakers go, but it will be fine for me.
bassage is offline
post #5 of 10 Old 05-13-2013, 02:34 PM - Thread Starter
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
Sitting about 16 feet away, I have a projector, not a tv.
bassage is offline
post #6 of 10 Old 05-13-2013, 03:09 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I suggest that you look at the Polk R150 speakers.
Mount a small shelf on the wall to put them on.
commsysman is offline
post #7 of 10 Old 05-13-2013, 03:26 PM - Thread Starter
bassage's Avatar
Quoted: 128 Post(s)
Liked: 29
I will look into those, thanks. I also just came across the Onkyo HT-S 9400 HTIB setup that seems to be getting great reviews. I'm also looking to buy a new receiver, so maybe I should consider it.
bassage is offline
post #8 of 10 Old 05-13-2013, 03:47 PM
Nethawk's Avatar
Liked: 118
I have no idea how these speakers review, but was just browsing through accessories4less and saw Boston Acoustics A2310 HTS 5.1 Speaker System for $449.
Nethawk is offline
post #9 of 10 Old 05-13-2013, 10:03 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
It's just a tiny bit above your budget (100x5=500), but the Cambridge Audio set might work great for you. They have a much better sound than any of the HTIB or satellite systems mentioned. They're considered by many in the forums as a best bang-for-the-buck speaker at their price point.
S30 pair LR mains $220
S50 center $200
S20 pair surrounds $150
$570 total
Or for budget reasons, you might try using two of your existing speakers (maybe the LR mains sound the best?) as surrounds for a while and just get the S30 pair and the S50 center ($440 initial expenditure).
sdg4vfx is offline
post #10 of 10 Old 05-14-2013, 05:15 AM
Terry Newton's Avatar
I am using Paradigm speakers and they are perfect for my small apartment.
Find the price range you want to spend and listen to that brand.
They sound great,5.1.
http://www.paradigm.com/
Terry Newton is offline
Reply Speakers
