Recommend HT speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-14-2013, 05:42 AM - Thread Starter
sid369's Avatar
Quoted: 43 Post(s)
I have been reading for weeks and I can't seem to decide what to get.
I have a large room 22X19 and one side open to kitchen, foyer. I want to get clarity and the ability for the sound to fill the room. I will add a sub later.
I have so far listened to
focal chorus 726v
polk tsi300
B&W CM9
Martin logan monitor 40
Def tech 8040
KEF Q700
I really liked how the B&W sounded and soon as the guy switched from the martin logan's to the CM9, I could heard that sound widen, it sounded more clear to me as well. but its not in my budget.
I have never had speakers before, just a $300 HTIB, which I think is good because I don't have anything else to compare it with.
So, maybe I am reading too much, but I don't want to buy something just because its at a certain price point it must be good. I almost bough the infinity primus p363 which gets good reviews and is considered a great bang for the buck speakers, but aesthetically they don't look appealing.
I also have the plk rtia7 in my list, but too many people say that I can get something better for the price.
Any logical recommendations or pointers.
sid369 is offline
post #2 of 5 Old 05-14-2013, 06:16 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
focal chorus 726v
polk tsi300
B&W CM9
Def tech 8040
KEF Q700
Low cost high quality alternatives:
The Pioneer "Famous Designer" small bookshelves and floor standers:
http://www.avsforum.com/t/1278774/pioneers-speaker-genius-hits-low-price-point
http://www.amazon.com/Pioneer-SP-C22-Designed-Channel-Speaker/dp/B008NCD2EI
http://news.cnet.com/8301-13645_3-57490890-47/mission-impossible-design-great-sounding-affordable-speakers/
Infinity Primus bookshelves and floor standers:
http://www.amazon.com/Infinity-Primus-P363-Three-way-Floorstanding/dp/B0046A8R3M
http://www.avsforum.com/t/722636/infinity-primus-owners-thread
http://seanolive.blogspot.com/2012/05/more-evidence-that-kids-even-japanese.html
arnyk is offline
post #3 of 5 Old 05-14-2013, 08:09 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
First, what's your budget.
Second, what speakers did you like the best that you heard within your budget range?
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #4 of 5 Old 05-14-2013, 08:15 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
And how far will you be sitting from the speakers?
When you do add a sub down the road, you also need to factor in the other rooms that this room is open to to get the total cubic square footage.
Perhaps you can rank the speakers you have listened to in terms of what you liked the most/least? That could help. I would also look at the Focal and Kef speakers at accessories4less if you liked those brands. They are typically sold at that site (they are authorized) for some good discounts, especially if you buy open box. You will 100% want to add a sub or two for any system. Some of the speakers you listed will sound quite different when crossed over at 60-80hz. When you demo, I would try to demo with and without a sub.
ack_bk is offline
post #5 of 5 Old 05-16-2013, 10:39 AM - Thread Starter
sid369's Avatar
Quoted: 43 Post(s)
Rank in order, although I don't remember exactly how they sounded but here it goes.
1. B&W CM9
2. focal chorus 726v
3. polk tsi300
4. Martin logan monitor 40
5. KEF Q700
6. Def tech 8040
Will be sitting about 15 -16 feet away from the speakers
sid369 is offline
Reply Speakers
