Speaker Compatibility? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-14-2013, 09:36 AM - Thread Starter
HogFan2's Avatar
Quick breakdown... The wife won't let me put a center channel on the mantle because it will take up too much space for her pretty knick knacks, but I do not have enough available space on either side of the TV for in wall fronts. I have found some Infinity products that I think are pretty comparable, but looking for a little expert insight into whether or not the "voice match" will be good enough.
The center channel is "Infinity ERS HV250". The specs on the speaker are as follows:
Enclosure Type In-wall
Video Shielded No
Tweeter Dome
Midrange Size ---
Woofer Size 5
Woofer Composition C.M.M.D.
Woofer Surround Rubber
Power Range (Watts) up to 125
Sensitivity 89 dB
Impedance (Ohms) 8
Frequency Response 45-22kHz
Connector Type Post
Bi-Amp Inputs No
The bookshelves are "Infinity Primus P163". The specs on these speakers are as follows:
Enclosure Bass Reflex
Video Shielded Yes
Tweeter Type Dome
Tweeter Size (inches) 0.75
Midrange Size (inches) N/A
Woofer Size (inches) 6.5
Woofer Composition M.M.D.
Power Range 10-150
Sensitivity 90 dB
Impedance (Ohms) 8
Frequency Response 49-20k Hz
Connector Type 5-way post
Bi-amp Inputs No
There are some differences here. A few of my thoughts:
1 - The center channel is not video shielded. is this a big deal?
2 - The woofer composition is a different.
3 - The sensitivity and frequency response seem close enough, but I am not exactly an expert on this sort of thing
HogFan2 is offline
post #2 of 6 Old 05-14-2013, 12:09 PM
unavol's Avatar
Quoted: 43 Post(s)
Liked: 48
1. If you're using an LCD or plasma an unshielded speaker shouldn't really affect it.
2. I've never heard those speakers, but since they are both Infinities I'd guess that they should be fairly close even if they aren't an exact timbre match. I don't think the bass driver material matching is as big a deal as the tweeter material. Do you know what the tweeters are made of on each speaker?
3. The sensitivity and FR are close enough. If you have an AVR with some type of room correction (Audissey, MCACC, YPAO, etc) it should be able to resolve that fairly easily. What AVR ar you using?
unavol
There's nothing to see here.
unavol is offline
post #3 of 6 Old 05-14-2013, 12:35 PM - Thread Starter
HogFan2's Avatar
Crutchfield said that both tweeters are using the proprietary infinity MMD metal driver. The in wall speaker is actually running CMMD, but they said that the metal driver being the same was the most important.
As for the receiver, I'm needing to pull the trigger very soon, but can't decide. Right now I'm looking at the Denon 1913 and the new Onkyo 525. I was sold in the Denon, but finding out that it didn't support Rhapsody threw me back in the fence.
HogFan2 is offline
post #4 of 6 Old 05-14-2013, 02:19 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
I suggest that you check out the Harman-Kardon 1700 receiver. IMO it is the best-sounding receiver in its price range (under $500).
It also has superb connectivity and interfacing for streaming etc.
commsysman is offline
post #5 of 6 Old 05-14-2013, 03:56 PM
gtpsuper24's Avatar
Liked: 99
Harmon Kardon 1700 only got 2.5 stars from Hometheater, for sound quality. The Yamaha RX-V473 got 4.5 stars for sound quality and its $49 cheaper.
http://www.hometheater.com/content/yamaha-rx-v473-and-rx-v573-av-receivers
http://www.hometheater.com/content/harman-kardon-avr-1700-av-receiver
both the RX-V473 and RX-V573 sound fantastic for receivers in this budget range. if you’re not hung up on all the latest over-the-top features, and don’t have tons of devices to hook up to an A/V receiver, both the RX-V473 and RX-V573 deliver something that so few receivers in this price range do: really, really solid sound quality for the coin.
Aren't you all about sound quality first before "whiz bang sound degrading features" ? Seems like the Yamaha would be the one you should suggest.
gtpsuper24 is offline
post #6 of 6 Old 05-14-2013, 04:15 PM
Badouri's Avatar
Liked: 56
Taking this advice from another thread:
The review by "What Hi-Fi" says that the sound quality is very good on the ...
This is a source for some reviews that are very critical if the sound quality of a unit is not up to par.
You can depend on what they say, in my experience.
You get: http://www.whathifi.com/awards/2012/home-cinema-amplifiers
The Pioneers are Class D
http://www.pioneer.eu/eur/products/42/98/405/SC-LX56-K/page.html
http://www.pioneer.eu/eur/products/42/98/405/SC-LX86-K/page.html
Badouri is offline
Reply Speakers
