In-Ceiling Speakers for Music and Movies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 58 Old 05-16-2013, 10:16 AM - Thread Starter
prnoct90's Avatar
I am looking for in ceiling speakers that will function as both the rear surrounds for my 5.1 system and for music. I watch about as much tv and movies as I do listen to music, so they need to be good for both of these things. I listen to pop, R&B and light rock. Budget is so hard to decide. I was thinking at most $200 per speakers, but I would rather wait and save and get speakers I will be happy with longterm than buy speakers right now and have to replace them in the future because they aren't good enough.
The Polk Audio RC80i are tempting, but I am just that price just seems to good to be true, and I dont want to have buyers remorse.
prnoct90 is offline
post #2 of 58 Old 05-17-2013, 11:53 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
In-ceiling speakers should never be used for serious music listening. In-walls for the LCRs would be much better.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 58 Old 05-17-2013, 10:01 PM - Thread Starter
prnoct90's Avatar
Unfortunately, they are my only option. I am currently comparing AIM8 Threes and Deftech speakers. It is a smallish room though (like 10ft x 9ft) so I wonder if Deftech would be overkill? I'd say my budget for five speakers is like $2000 (I could put the center speaker below the TV though).
So the current options I am looking at are:
Option 1
4 SpeakerCraft AIM8 Three (Left, Right, Rears)
1 Speakercraft AIM LCR3 Three (Center)
Sub
Option 2
3 Definitive Tech UIW RCS III (LCR)
2 Definitive Tech UIW RSS III (Surround)
Sub
Has anyone actually had a chance to compare the speakercraft AIMs and the DefTechs?
**With regards to an enclosure, the definitive tech seems to have one built in, and speaker craft sells one, but unfortunately it looks like it can only be used for pre drywall installations, and this will be installed into my existing room.
prnoct90 is offline
post #4 of 58 Old 05-18-2013, 05:42 AM
BobL's Avatar
Liked: 56
To get the best sound out of speakers they need to aim at you.  Most of the angled speakers like the Speakercraft AIM only angle to ~15 degrees, which means they are still pointing mostly down and not at the listeners.  Look for speakers that angle 30 degree or more.  The Deftechs should work.  Some other brands to consider.
Paradigm 30 degrees - Various models starting at $279
Triad 35-45 degrees - Various models starting at $600
Episode 700 series 45 degrees - $799
Thiel Powerpoint (on-ceiling) 60 degrees - $1499
JBL LS360 30 degree - $549
There are probably others I'm not thinking about, but I wouldn't use LCR speakers with only 15 degrees unless you are sitting 3 feet from them.
BobL is offline
post #5 of 58 Old 05-18-2013, 06:25 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Option 1
Sub
Option 2
Sub
I own Speakercraft AIM series upstairs in the family room, and Deftech UIW RLS and RSS speakers in the media area. There is no comparison in my opinion. The Deftech speakers are head and shoulders better.
BobL makes some great recommendations, aside the angle of speaker woofer/tweeter, I would not buy a speaker that does not either have an engineered enclosure, or one that offers an enclosure as an add-on.
What are you thinking in terms of the sub?
ack_bk is offline
post #7 of 58 Old 05-18-2013, 07:41 AM
BobL's Avatar
Liked: 56
I agree that an enclosure or back box is recommended as speakers sound different depending on the size of cavity they are placed. It will often change the sound in the bass/ mid bass area and of course have bleed through into adjacent rooms.  Part of this will depend on budget though and back boxes often are not easy to retrofit unless you don't mind patching drywall which isn't hard but raises the cost.  Any of those I mentioned are either enclosed or have a back box available.
For surround speakers I'd use more of a bi-pole/ di-pole speaker to get better envelopment or if you use 5 of the same speakers angle the surrounds at the side walls for better dispersion and less localization of the surround sound.  In your small space you are probably seated too close to get them wide enough to angle them towards the listening position.
If you plan to use in ceiling speakers for the front speakers none of those Revels linked would work for your application.  Revel does make nice speakers and their C763 would be fine for the fronts, it is the same as the JBL design with different drivers.  They are both Harman companies.  And for the surrounds you could use one of their DT (dual tweeter) models or angle towards the wall if using 5 of the same speakers.  These would be better choices for your application.
http://www.ebay.com/itm/Brand-New-Revel-C763L-In-Ceiling-Speaker-with-Grill-each-/310669578438?pt=Speakers_Subwoofers&hash=item48555990c6
http://www.ebay.com/itm/Brand-New-Revel-C363DT-In-Ceiling-Speaker-with-Grill-each-/310669578334?pt=Speakers_Subwoofers&hash=item485559905e
http://www.ebay.com/itm/Brand-New-Revel-C563DT-In-Ceiling-Speaker-with-Grill-each-/310669578408?pt=Speakers_Subwoofers&hash=item48555990a8
BobL is offline
post #8 of 58 Old 05-18-2013, 10:43 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
Of course, the higher end Revel will be the best for the application. But his budget is only $200 per speaker.
AcuDefTechGuy is offline
post #9 of 58 Old 05-18-2013, 11:06 AM
BobL's Avatar
Liked: 56
I put it as reference as the ones you linked aim straight down and not towards the listener, they wouldn't work for this situation.  Also, he is considering Speakercraft and Deftech which are retail $300-$600 so I didn't think it was out of his budget.  The least expensive is probably paradigm with a MSRP of $279.
BobL is offline
post #10 of 58 Old 05-18-2013, 01:24 PM - Thread Starter
prnoct90's Avatar
I actually have enough space under the tv for the center speaker (unfortunately not enough for all three front speakers due to doors), would it be better to put the center speaker under the TV and then use the C763L for right and left, or should I just stick to the C763L for all three? If it would be better to use an in wall, which would your recommend that is timber matched?
Anyone know the difference between the C363DT and the C563DT? Is it worth the extra money for the C563DT? Also, are these timber matched with the C763L?
Would it be a problem for music listening that these are all different?
Also, I'm still stuck with the speaker box problem even with these right?
prnoct90 is offline
post #11 of 58 Old 05-18-2013, 01:26 PM
Quoted: 175 Post(s)
Liked: 262
the ones you linked aim straight down and not towards the listener.
Gotcha.
post #12 of 58 Old 05-18-2013, 01:34 PM
Quoted: 175 Post(s)
Liked: 262
If you could do in-wall, that would be better than in-ceiling.
Depends on your budget; higher-end will sound better, but even the $200 will still sound great.
http://www.ebay.com/itm/Brand-New-Revel-W873-In-Wall-Speaker-with-Grill-each-/321125592213?pt=Speakers_Subwoofers&hash=item4ac493ac95
http://www.ebay.com/itm/Brand-New-Revel-W583-In-Wall-Speaker-with-Grill-each-/321125592174?pt=Speakers_Subwoofers&hash=item4ac493ac6e
http://www.ebay.com/itm/Brand-New-Revel-W253L-In-Wall-Speaker-with-Grill-each-/230978072596?pt=Speakers_Subwoofers&hash=item35c75db014
post #13 of 58 Old 05-18-2013, 01:55 PM - Thread Starter
prnoct90's Avatar
Ok, just kidding, I ended up getting the
Definitive Tech UIW RSS III x 2
because I got a really good deal on a last minute auction.
So, my question now is, should I get 3 of the RCS III for LCR, or should I get two for LR and put an in wall below the TV? If so, which would be good to go with these speakers?
(Maybe this one?
http://www.definitivetech.com/products/uiw-rls-iii
prnoct90 is offline
post #14 of 58 Old 05-18-2013, 02:15 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
How large is your screen? Would a speaker bar fit below? You could get LCRs right below the screen.
http://www.revelspeakers.com/images/prodphotos/prod_60_634503033234720497_LCR8-Front-Black.jpg
4DHD is offline
post #15 of 58 Old 05-18-2013, 02:53 PM - Thread Starter
prnoct90's Avatar
yah, i considered a bar, but it would look bad in the space do t space contraints, and it wouldnt be very good for music
prnoct90 is offline
post #16 of 58 Old 05-18-2013, 03:22 PM
BobL's Avatar
Liked: 56
I would do all three in the ceiling.  The center below will not allow good pans across the front soundstage as there is too much difference in height between the center and L/R.  When possible it is best to use 3 identical speakers all at the same height.  You would be able to achieve this with the in ceilings.  As a general rule it is preferable to have the speakers at ear height but that will be line compromise you'll have to make.  If the TV is mounted high the in ceilings can still give the illusion that the sound is coming from the TV.
BobL is offline
post #17 of 58 Old 05-18-2013, 08:50 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
ack_bk is offline
post #18 of 58 Old 05-19-2013, 03:10 AM - Thread Starter
prnoct90's Avatar
I was probably gonna go for the RCS III because of space contraints, but will listening to dual stereo on RCS and RSS sound funny? Or are they close enough?
prnoct90 is offline
post #19 of 58 Old 05-19-2013, 09:55 AM - Thread Starter
prnoct90's Avatar
It looks like maybe if I move some stuff around, I could clear an area that is about 50" wide below the TV. While I really like the cleanliness the RCS III provide, I could hypothetically put three UIW RLS III together it would be about 40" of speaker with about 2.5" between each speaker. In other words, it would be very smashed and not very separated at all. Won't I get a better result with more separation (via the RCSs)? Unfortunately, floor standing arent an option (wish I could)
prnoct90 is offline
post #20 of 58 Old 05-19-2013, 12:46 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
A top quality soundbar like the Revel LCR8 would provide better 3 channel sound than placing LCRs too close to each other.
The LCR8 is just under 40" long.
4DHD is offline
post #21 of 58 Old 05-19-2013, 06:53 PM - Thread Starter
prnoct90's Avatar
Cant find the Revel LCR8 anywhere for sale
prnoct90 is offline
post #22 of 58 Old 05-20-2013, 05:00 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I would email Revel asking where it can be purchased. Over the years, I've found the Harman brands to have very good customer service.
4DHD is offline
post #23 of 58 Old 05-21-2013, 12:21 PM - Thread Starter
prnoct90's Avatar
yah, i thought it was important to get all your speakers from the same company
prnoct90 is offline
post #24 of 58 Old 05-21-2013, 12:28 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Same brand and usually same series. A mis-match of brands can result in anything from 'not too bad', to 'terrible'.
4DHD is offline
post #25 of 58 Old 05-21-2013, 01:04 PM - Thread Starter
prnoct90's Avatar
Well, then what are a good soundbar, in ceiling surrounds that are all from the same series within a $2000 budget?
prnoct90 is offline
post #26 of 58 Old 05-22-2013, 01:02 AM - Thread Starter
prnoct90's Avatar
the only reason I was partial to the def techs is they are enclosed
prnoct90 is offline
post #27 of 58 Old 05-22-2013, 03:24 AM - Thread Starter
prnoct90's Avatar
Ok, I switched things up for the sake of brand consistency, and I chickened out with getting all in ceiling for all five so here is the new plan.
1 x Revel Concerta LCR8
2 x Revel C563DT
Thanks for all the advice, and hopefully this will sound good. Will just stuffing some fiberglass insulation behind these be enough?
EDIT: Why were the dual tweeter recommended? Would each speaker need two sets of cables?
BTW, Here is a quick mockup of my room
prnoct90 is offline
post #28 of 58 Old 05-22-2013, 05:01 AM
BobL's Avatar
Liked: 56
Dual tweeters help with better envelopment for surround applications, it helps them from being too localized. You don't need to run two sets of speaker wires, but you do need to connect both terminals. You run a small wire from one terminal to the other and the small wire will connect the opposite leads i.e. Black to red, and red to black. The reason there are two terminals as they can be used to get stereo sound in small areas like a hall or small bathroom, in that application you would have to run two sets of wires. I think using the sound bar is a good choice for your application.
BobL is offline
post #29 of 58 Old 05-22-2013, 05:11 AM - Thread Starter
prnoct90's Avatar
The only other option I was considering now was three of the C763L. The problem is, I really can't find reviews on either the soundbar or the C763Ls. It is very frustrating. Why are there no reviews anywhere for this stuff? It keeps making me second guess it
prnoct90 is offline
post #30 of 58 Old 05-22-2013, 05:25 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
If its Revel its usually all good. The one exception to Revel is the Gem2 speaker. It is a very good speaker, but JBL PT800 is almost identical in design and much cheaper. In fact the Gem2 was designed based on the PT800. But that is OT.
I have not even seen prices for the LCR8. I think I did see a review a few months back, but I don't remember where.
And looking at your new drawing, I can say my thoughts towards the LCR8 would be the right choice with those two doors to either side.
4DHD is offline
Reply Speakers
In Ceiling Speakers , Polk Audio Rc80i 2 Way In Ceiling Speakers Pair White
