Help finding a center speaker for existing setup. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-17-2013, 06:36 AM - Thread Starter
drewman21's Avatar
Good morning all,
I am a bit of a speaker novice and I need some help selecting a center channel for my 5.1 surround setup. I have a bit of a cobbled together system which consists of the following. A Mirage sub model PS-12-90 and four JBL Control 25T speakers that have been switched over to 8ohm use and the transformers removed. The receiver I have is a Harmon Kardon AVR1700.
Mirage Sub PDF
Control 25T info
AVR 1700
I don't know much on how to figure out how to decide on a center channel speaker but I would be interested in some tips to figure it out for myself. Or if anyone could provide a suggestions for a speaker that would be in the $80-100 range that would be great. I am pretty broke at the moment (and for the near future) so changing out the gear I have already is not much of a option for me. Not that cheaper is better but I would like to know what I would need to save up for if it is much more than $100.
Thanks for any help you guys can provide!
Have a great Friday.
Andrew J
drewman21 is offline
post #2 of 7 Old 05-17-2013, 06:53 AM
Elihawk's Avatar
Quoted: 1340 Post(s)
Liked: 1172
the only center people should be recoomending is the matching center for the JBL25T control speaker...
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #3 of 7 Old 05-17-2013, 07:00 AM
eljaycanuck's Avatar
Quoted: 1352 Post(s)
Liked: 1964
I'd put one of the JBL Control 25Ts to work as a CC speaker - which would give you a timbre-matched front soundstage - and spend ~$100 on a new pair of surrounds.
-- Edit --
Amazon.com has JBL ES20 bookshelf speakers on sale for $130, shipped. They could be a viable option for surround use.
eljaycanuck is offline
post #4 of 7 Old 05-17-2013, 08:50 AM
hdnewbie21's Avatar
Liked: 38
-- Edit --
^^^^^^This^^^^^^^
Yamaha RX-V673 | HSU HC-1 MK2 | HSU HB-1 MK2 - LR | Pioneer SP-BS22-SLR | BIC RtR-V44-2 (Presence)
hdnewbie21 is offline
post #5 of 7 Old 05-17-2013, 09:33 AM
crn3371's Avatar
Quoted: 258 Post(s)
Liked: 206
If you absolutely need to run a center, then using one of your 25T's like everyone mentioned is your best option. Frankly, I'd hold off on the center and save up until you can get some new front speakers. Those 25T's are pretty limited speakers and ultimately you'd be better served relegating them to surrounds and get new fronts.
crn3371 is offline
post #6 of 7 Old 05-17-2013, 05:12 PM
sdg4vfx's Avatar
Quoted: 118 Post(s)
Liked: 153
-- Edit --
+1
sdg4vfx is offline
post #7 of 7 Old 05-20-2013, 10:36 AM - Thread Starter
drewman21's Avatar
Thank you all for your help. The speakers that were suggested seemed great for the cost. Unfortunately the added cost and the need for me to buy a mounting setup to get them up higher (small kids) Puts it out of my price range. I will for the time try and find a single Control 25 speaker for my setup and use that till I can afford a better left, right, and center option. Thanks again!
Andrew J
Reply Speakers
