5.1 rear speaker placement? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 05-18-2013, 11:24 AM - Thread Starter
RON82ND's Avatar
So I am ready to mount the rear speakers but thought I should get some advice before I do. My sofa is up against a back wall that on one side opens to the kitchen and the other to a hallway leading to the garage. My question is should I mount them on the sides at a 90 degree like I believe is my only choice or could I get away with mounting them over our heads? Also on as far as the opening to the kitchen and garage I could fire them into the side walls if that would be better but not sure what to do. I thought having them on the ceiling as well what is everyone's opinion?
RON82ND is offline
post #2 of 2 Old 05-19-2013, 09:15 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Being your seating is against the wall, if possible, I would place them into the corners on 45* angles.
There are many speaker mounts that would allow you to do that.
I would not place them overhead.
http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-MS56B/dp/B000X9O8SI/ref=sr_1_4?ie=UTF8&qid=1368980071&sr=8-4&keywords=wall+speaker+mounts
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Reply Speakers
