Speaker switch - AVS Forum
post #1 of 9 Old 05-18-2013, 04:20 PM - Thread Starter
Newman15's Avatar
New to forum, I have a newer pioneer receiver (822k) and it does not support speaker A and B. if I had known this when I bought it I would of upgraded. We are finishing back yard and installing exterior speakers that I wanted to wire into the receiver as it has airplay. But I'm stuck. No way to switch speakers. Can I buy one of these switches and put it on the wire line. I really have no idea what to do. I'm open to ideas. You guys steer me right here please.
Newman15 is offline
post #2 of 9 Old 05-18-2013, 04:40 PM
lovinthehd's Avatar
Quoted: 130 Post(s)
Liked: 744
You have read page 14 of your manual and followed the instructions and it doesn't work? http://www.pioneerelectronics.com/PUSA/Unassigned-Content/Manuals/VSX-1022-K+OPERATING+INSTRUCTIONS
ps crap, misread that on the first go....d'oh I hate that Pioneer sharing of manuals between models.
Yes, sometimes you have to read the specs....but when I looked for a list of features I didn't see zone or a/b mentioned...
lovinthehd is offline
post #3 of 9 Old 05-18-2013, 06:41 PM - Thread Starter
Newman15's Avatar
Yea it's the 822 and doesn't support zone or a, b. could i do switch?
Newman15 is offline
post #4 of 9 Old 05-18-2013, 06:53 PM
lovinthehd's Avatar
Quoted: 130 Post(s)
Liked: 744
I don't see why not as long as the switch is appropriate to your setup and use. why not just get a small amp instead and use the pre-outs? Too late to return the 822?
post #5 of 9 Old 05-18-2013, 07:58 PM - Thread Starter
Newman15's Avatar
It's to late to return it, if I got a small amp I wouldn't be able to wirelessly control it from my iPhone how I can now
Newman15 is offline
post #6 of 9 Old 05-18-2013, 08:33 PM
lovinthehd's Avatar
Quoted: 130 Post(s)
Liked: 744
You need more than controlling the volume?
post #7 of 9 Old 05-18-2013, 08:42 PM - Thread Starter
Newman15's Avatar
Song changes from iTunes, And to not have my satellite sound playing though outside speakers
Newman15 is offline
post #8 of 9 Old 05-18-2013, 08:47 PM
lovinthehd's Avatar
Quoted: 130 Post(s)
Liked: 744
Where's your iTunes? You can control it now on your phone or remote don't see why that would change. The only downside I see is the loss of on/off on the speakers, i.e. being able to turn off B from outside, if using another amp, it's not the front height channel feed, it's a speaker B (2 ch) feed, i.e. your l/r speakers.
PS our are you wanting multichannel sound outside?
PPS now I reread that bit I think my fuzzy head today did it again (home sick)....it appears only to allow you multiple channel access if you read it one way, but why call it speaker b if it doesn't play the mains? Sneaky to call it speaker b if it doesn't play the main channels.
Have you looked for a thread for this particular avr? Might be some insight there.
post #9 of 9 Old 07-10-2013, 07:21 PM - Thread Starter
Newman15's Avatar
sorry for the extremely long reply. Yes I want to run multichannel outside. I don't care about controlling speaker switching from outside. I temporarily bought a speaker switch, And it does work fine, however the impedance poses a problem as it will over heat my receiver running 4 fronts.. Unless I leave off my interior front speakers.(but the rears and centre, sub are still on).... As per the pre outs on the back, I tried hooking up an older 2.1 amp to the pre outs via the CD input on the older amp. But I get no sound. It says they are for front height and surround back speakers. can someone explain pre outs? I might look at getting a better speaker selector switch, Unless you can think of something else. Returning the receiver is not an option.
Newman15 is offline
Reply Speakers
User Tag List
