?s about front towers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 05-20-2013, 07:56 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
I'm looking for a pair of tower speakers to replace my old JBLs. I'm looking for great bass and under $300 per.
bloodta is offline
post #2 of 23 Old 05-20-2013, 08:58 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Old JBL what model? Old JBL covers a LOT of ground. Great bass at under $300 each? Not likely.
lovinthehd is offline
post #3 of 23 Old 05-21-2013, 05:22 AM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
They are Northridge E60 I believe. Great bass compared to these, is what I'm after.
bloodta is offline
post #4 of 23 Old 05-21-2013, 08:16 AM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
I'd look at the Primus p363 towers
Panny 65st60 / Denon X1000 / EMP e55ti / EMP e56ci / EMP e5bi / (2) e1010i
Selling 1 e1010i sub: http://www.avsforum.com/forum/209-au...al-10-sub.html
ousooner2 is offline
post #5 of 23 Old 05-21-2013, 08:43 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
If you want great bass, get a powered subwoofer!!
Infinity P363 is a very good speaker but I dont know if it has "great bass".
Afro GT
afrogt is offline
post #6 of 23 Old 05-21-2013, 09:55 AM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
Can you do bookshelves OP? I'm sure you could put together something a little better in regards to bass output with that budget if you went with a pair of bookshelves & a sub
post #7 of 23 Old 05-21-2013, 01:43 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
I have 2 powered subs. Im looking for some nice towers to compliment the subs. Something to do that mid range bass. I feel as though there is a drop off from my fronts to my subs, like a gap.
bloodta is offline
post #8 of 23 Old 05-21-2013, 04:03 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
What is your crossover set at?
Most good bookshelf speakers crossover fine at 80hz (the crossover recommend by THX for HT). My bookshelf speakers (which cost less than $300 a piece) are crossed over at 60hz and there is no gap.
+1 the earlier comment ... at that price range you can probably get better quality bookshelf speakers than towers.
sdg4vfx is offline
post #9 of 23 Old 05-21-2013, 04:49 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
The sub is set at 120 the fronts are set to Large
bloodta is offline
post #10 of 23 Old 05-21-2013, 05:06 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
With that setting, on most avr's, you're not getting anything out of your sub on 2 channel music. Try setting your speakers to small, crossover around 80hz.
crn3371 is offline
post #11 of 23 Old 05-21-2013, 05:22 PM
myoda's Avatar
Liked: 57
It would assist if you could tell us about your stuff. Type of sub, receiver, etc. Is it possible that your subs are getting in the way (sonically) of your JBL's? Where are your subs located? How much power are you feeding the E60's? Have you thought about upgrading to one really good sub? Back in the day, the E60 had respectable sound, but was lacking in bass. Do you have 2 matching or mis-matched subs?
myoda is offline
post #12 of 23 Old 05-21-2013, 05:23 PM
lovinthehd's Avatar
Liked: 4775
Might not need new speakers now...good call guys!
post #13 of 23 Old 05-21-2013, 07:08 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
I have an Onkyo 805, 2 PA-120 subs. One sub is at the front of the room next to the left front tower. The other is in the rear left corner. I used the sub crawl method to place them. I used Audessey to set up, as well as an SPL meter to calibrate the levels.
bloodta is offline
post #14 of 23 Old 05-21-2013, 07:29 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
I don't know how Onkyo handles it (Yamaha user) but I'm under the impression that when your speakers are set to large that the only thing the sub gets is the LFE signal. Fine for movies, maybe not so fine for music. Setting the speakers to small sends the sub the LFE signal and everything below whatever cutoff freq. you've selected.
crn3371 is offline
post #15 of 23 Old 05-21-2013, 07:59 PM
lovinthehd's Avatar
Liked: 4775
The 805 manual isn't very helpful on what it does exactly that I can see. However, it isn't Audyssey recommending small, it's the AVR, Audyssey says if you have a sub, set your speakers to small. On my Onkyo I use small for my mains FWIW. I'd try crossing over at 80 and maybe 60 with the mains set to small and see what you think in any case.
post #16 of 23 Old 05-21-2013, 08:08 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
There is no small setting, there is Full Band, then from 90hz down to 40hz I think
bloodta is offline
post #17 of 23 Old 05-21-2013, 08:12 PM
lovinthehd's Avatar
Liked: 4775
Essentially the same thing, full band yields no crossover, selecting a crossover gets one (the difference between large and small)
post #18 of 23 Old 05-22-2013, 02:52 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
Ok, let me see if I understand correctly, I should set the sub's xover as high as it will go on the sub and let my avr handle the xover? Also, the lower the number, the higher the frequency? (40 hz is high 200hz is low)?
bloodta is offline
post #19 of 23 Old 05-22-2013, 04:04 PM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
Your receiver handles crossovers like so:
Full/Full Band: this means there will be no crossover applied and they will play the full bandwidth of the receiver (20hz-20kHz usually)
...From there there can choose certain crossover points (100hz, 90hz, etc etc). This means that any material BELOW that point will be sent to your subwoofer
The lower the number, the lower the frequency. Check out this link and it will begin to make more sense..
http://www.independentrecording.net/irn/resources/freqchart/main_display.htm
post #20 of 23 Old 05-22-2013, 04:07 PM
lovinthehd's Avatar
Liked: 4775
Yes, either move the sub's crossover to max setting or use an LFE input on the sub (which would bypass the crossover on the sub), and let the avr do the crossover. Lowest frequency is the lower number (Hz = cycles per second). General THX crossover is recommended for 80Hz, but keep in mind it's not a specific point type of crossover but defining a beginning point for a slope, so even when you set a crossover at 80 doesn't mean your main speakers won't put out sound below 80Hz, they're just being instructed to put out less and less as the frequency drops). I'd try 80 first, then 60 (override your avr's recommendation after you run Audyssey).
post #21 of 23 Old 05-22-2013, 04:14 PM
ousooner2's Avatar
Quoted: 259 Post(s)
Liked: 149
Emphasis on "recommended". An 80hz crossover is just a starting point to try. Interactions will be different for everyone so try different crossover points until you achieve what you like
post #22 of 23 Old 05-22-2013, 06:27 PM - Thread Starter
bloodta's Avatar
Quoted: 65 Post(s)
Ok guys, thanks for all the help. I think I got it dialed in. My front towers a rated at 40hz-20kHz, so I set the crossover at 80hz.
bloodta is offline
post #23 of 23 Old 05-22-2013, 08:52 PM
lovinthehd's Avatar
Liked: 4775
Glad to hear you got it sorted. Enjoy!
Reply Speakers
Jbl Northridge E60 3 Way 8 Inch Floorstanding Speaker Single Black Ash , Infinity Primus P363 Three Way Dual Infinity Floor Standing Speaker , Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver
