DCM Timeframe TF-1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-21-2013, 07:09 AM - Thread Starter
DsoundR's Avatar
I own a pair of TF 1000 and unfortunately the midrange driver cone is torn. Would anyone have any insight on the spec for that driver, know the specs/crossover frequencies/points for the speakers, or know where I can find a viable component replacement? I am a newbie to the audiophile community and am trying to learn as much as possible, but I do have a BS in Civil Engineering... With some technical capacity.
DsoundR is offline
post #2 of 5 Old 05-21-2013, 11:49 AM
dholmes54's Avatar
Quoted: 490 Post(s)
Liked: 142
I had the time frame 600 years ago,loved them,& had a mid range driver blow,check partsexpress.com they will find a driver for you, if you cant get a dcm replacement.
dholmes54 is offline
post #3 of 5 Old 05-21-2013, 02:54 PM
Gandu's Avatar
Quoted: 70 Post(s)
Liked: 90
You might try the AudioKarma speaker forum as well
Gandu is offline
post #4 of 5 Old 05-21-2013, 03:21 PM
smudge981's Avatar
Quoted: 51 Post(s)
Liked: 207
You might want to direct your question in the following thread for possible answers: "Whatever Happened To DCM's Steve Eberbach?"
"I am NOT suffering from insanity... I happen to be enjoying myself!"
smudge981 is offline
post #5 of 5 Old 05-22-2013, 06:57 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
^What he said. Go into that thread or pm Jamie Hauser. He's the resident DCM guru here.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Reply Speakers
