Klipsch Center Speaker options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-21-2013, 03:08 PM - Thread Starter
Ray Clubber Del's Avatar
Hi Guys, i'm new at this forum, well not exactly, i read it a lot! but this is the first time i write something, my name's Ray, and i have a question for you, i really hope you can help me with this...
I recently upgraded my Klipsch WF-35's to a RF-7ii, so, my 5.2set up is RF-7ii(bi-amp) as mains, WF-35's as rears, 2 Klipsch KSW 10 Subwoofers, and i have a polk audio CS1 as center channel speaker, powered by an Onkyo TX-NR 808 Receiver, i really don't like that much the polk audio sound so i'm going to replace the center channel; I can't afford the RC-64ii and i'm considering of buying either RC-42ii or RC-52ii, BUT i read here at the forums that the best center channel you can have is the one that match the mains, again, i can't afford a third RF-7ii, so the question is, what would you say if i use a RF-42ii or RF-52ii or even a third WF-35 as a center channel?
Thanks a lot for your comments!
Ray Clubber Del is offline
post #2 of 12 Old 05-21-2013, 03:36 PM
eljaycanuck's Avatar
Quoted: 1225 Post(s)
Liked: 1794
IMO, the RB-81 II and the RC-62 II are worth considering. Same make and same series, but relatively affordable.
eljaycanuck is online now
post #3 of 12 Old 05-21-2013, 04:08 PM - Thread Starter
Thanks a lot! i'll keep an eye on both, just one question, why do you think its better to buy a book shelf rather than a Floor standing?
post #4 of 12 Old 05-21-2013, 04:27 PM
Liked: 1794
No reason, other than a matter of space below the display. However, since you were considering towers for CC duty, I should have realized that space isn't an issue...in which case, the RF-52 II would be a solid choice.
post #5 of 12 Old 05-21-2013, 07:07 PM - Thread Starter
Thanks for your opinion, i forgot to post that i have a pair of celestion E5and other pair of celestion E2, what would be your opinion on any of these as center speakers?
post #6 of 12 Old 05-21-2013, 07:15 PM
Liked: 1794
Mixing brands of speakers across your front soundstage is not recommended, but since you have them anyway, you might as well try them out. Can't hurt, and it'll cost you nothing other that a bit of time. smile.gif
-- Edit --
post #7 of 12 Old 05-21-2013, 07:35 PM - Thread Starter
I'll try that, i love my celestions, they really sound nice, the pro's : i already have them, they are 3 way and sound real nice, and the only Con i have is that they are 4 ohm, and the receiver is set to 6 ohms, because klipsch are at 8 ohms, do you think that could be a problem?
post #8 of 12 Old 05-21-2013, 07:38 PM
Liked: 1794
I wish I could answer that, but I honestly don't know. Hopefully someone else will be able to provide the right info.
post #9 of 12 Old 05-21-2013, 07:44 PM - Thread Starter
Eljay, thanks a lot for your time and your advice! Let me tell you, you have an excellent HT Set up, congrats!
post #10 of 12 Old 05-21-2013, 07:53 PM
Liked: 1794
And I hope you're able to get your CC problem resolved without too much hassle.
post #11 of 12 Old 05-25-2013, 09:24 AM - Thread Starter
Does any one have an opinion? Thanks!
post #12 of 12 Old 05-28-2013, 05:46 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Try it.
psgcdn is offline
Reply Speakers
