Final Decision Time for L/C/R: 3 Pioneer AJ towers or 3 Infinity 163s - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-21-2013, 02:26 PM - Thread Starter
tampa frank's Avatar
I was about to order three Infinity Primus 163s to use for my front sound stage. I then came across the Best Buy sale on the Pioneer AJ towers for $100 each. Now I'm considering three of these to use for L/C/R.
This option (using towers) has opened up since I'm having no luck finding a media console to house all of my components. My plan was to mount the 61" TV to the wall with a large console under it housing my components. The three bookshelf speakers would be placed on top of the console. I'm not finding what I want in a console, so I might just go with an AV rack.
From a pure sound aspect, which would be better: three Primus 163's or three Pioneer AJ towers? A sub will be used with either choice.
tampa frank is offline
post #2 of 7 Old 05-21-2013, 02:36 PM
crn3371's Avatar
Quoted: 257 Post(s)
Liked: 206
I'd think that 3 towers would make a nice wall of sound. My only concern would be that your tv would be mounted kind of high to clear the towers.
crn3371 is online now
post #3 of 7 Old 05-21-2013, 03:00 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1351
I would go with the Pioneer towers over the Infinity bookshelf speakers.
shadyJ is offline
post #4 of 7 Old 05-21-2013, 05:36 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
How big is your room?
Would towers be overkill?
Or would they just naturally be the best choice?
bladerunner6 is offline
post #5 of 7 Old 05-21-2013, 07:28 PM
Bill Fitzmaurice's Avatar
Liked: 5667
The only advantage of towers over bookshelves is that towers go lower, for better bass if you don't have subs. If you do have subs they offer no advantages, and for the same price you should be able to get higher quality bookshelves. And as for subs you should use at least two, you can't smooth room modes with a single sub.
Bill Fitzmaurice is offline
post #6 of 7 Old 05-22-2013, 05:55 AM - Thread Starter
Living room is 17' x 20', but it is completely open to the kitchen on one side. I'll probably be sitting about 12' from the front speakers.
I want to use three identical speakers for the front soundstage. Bookshelves were the plan, but 9 mid-bass drivers seems like it would be better than 3 biggrin.gif.
This is ridiculous! It only took me one day to buy a house, but I've been stressing over this speaker decision for 3 months. I went from the Pioneers to the Hsus to the Infinitys and now back to the Pioneers. I'm sure that I will be happy with any of the above. I just need to make a decision and move on... wink.gif
post #7 of 7 Old 05-22-2013, 05:56 AM
Liked: 5667
Originally Posted by GIEGAR View Post
Hi Bill. What about improved power handling (= lower distortion; compression) above the sub crossover when "pushed" and moderately higher sensitivity when multiple woofers are employed on towers, which is usually the case? Just curious... smile.gif
The multiple woofers in towers are there to provide better capability below 80Hz. If you're not using the mains below 80Hz you want drivers designed to work best above 80Hz. Think pickup truck versus two seat sports coupe. If you're always hauling stuff the pickup is the better choice. If you never have more than one passenger and a couple of suitcases to carry the sports coupe is the better tool for the job.
Reply Speakers
