Center channel help/X-over help? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-21-2013, 09:39 PM - Thread Starter
avthokie's Avatar
I have 2 different center channel speakers to choose from at the moment. I have a Martin Logan Motion 8 or a DT 1000...I also have B&W 684 towers all powered by a Denon AVR 3312CI. I am primarily a movie/TV watcher. Very rarely use this setup for music. Just looking for input on which might be best and what crossover to set the fronts to. Thanks!
Denon AVR 3312ci--Samsung pn51e7000--Klipsch RC-62 II--2 Klipsch RF-82 II--Polk fxi-a4 surrounds--Panasonic DMP-BDT300--Xbox 360--PS3--Scientific Atlanta Explorer 8300HDC with TWC--2 Dayton sub 1200's
avthokie is offline
post #2 of 7 Old 05-21-2013, 10:43 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Are you running a sub? Otherwise crossover is moot. Also, not quite how good a non matching center channel is going to sound. If you are running a sub, I crossover my 684's at 60hz with them set to small.
crn3371 is offline
post #3 of 7 Old 05-22-2013, 05:36 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
I have 2 different center channel speakers to choose from at the moment. ... Just looking for input on which might be best and what crossover to set the fronts to.
Try both CC speakers, and go with the one that works best with your mains.
Run Audyssey, set all speakers to "small".
If the crossover on your mains is set lower than 80Hz, try raising it to 80Hz and see if that sounds better. If it does, leave it there; if it doesn't, drop it back down to whatever it was set to.
eljaycanuck is offline
post #4 of 7 Old 05-22-2013, 11:22 AM - Thread Starter
avthokie's Avatar
Hey Thanks. I am running a sub, set the receiver to LFE. It is not a powerful sub, just 150w 10 inch polk...
avthokie is offline
post #5 of 7 Old 05-22-2013, 11:24 AM - Thread Starter
avthokie's Avatar
Yeah I like the DT for clarity, the ML seems a little muddled. I had set the X-overs to 100 for the fronts and 120 for the center...just trying it out. I think i will lower them all to 80hz and just see from there. Thanks for the help...
avthokie is offline
post #6 of 7 Old 05-22-2013, 12:05 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
100hz seems pretty high for the 684's. Like I said, I'm using 60hz on mine. You've got a pretty weak sub, you might even try setting your fronts to large and enabling extra bass to see how that sounds.
crn3371 is offline
post #7 of 7 Old 05-22-2013, 03:55 PM - Thread Starter
avthokie's Avatar
I set the fronts to 80, and the center to 120 the surrounds are at 150. Seems to sound pretty good with my current set-up. I have old yamaha surr speakers from an out of a box 5.1 set...looking to upgrade those next.
avthokie is offline
Reply Speakers
