Cat.5E+16/4AWG Audio Combo Cable wired in house - AVS Forum | Home Theater Discussions And Reviews
Old 05-22-2013, 08:42 AM - Thread Starter
ainchene's Avatar
the old installer use Cat.5E+16/4AWG Audio Combo Cable
http://www.dalco.com/p-3470-500ft-cat5e164awg-audio-combo-cable-cmr.aspx
I removed the speakers and noticed it had standard red and black leads to all the speakers but where all the wires go to there is red, black, green, white along with Cat 5. Each room has only two speakers into 4 zones. I tried to ohm out the wire with no luck and also hook up my receiver and no audio out of the speakers. Does anybody know how the installer would of use this wire? I know that each room has a key pad plate but they were not used
ainchene is offline
