5.2 or 7.2 for movies - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-27-2013, 06:31 PM - Thread Starter
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
I want to know if 7.1 or 7.2 is necessary for movies since the majority of movies are 5.1. I have only one movie that is 7.1
blee0120 is online now
post #2 of 6 Old 05-27-2013, 06:35 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It's more dependent on the size of your room. The larger rooms do better with 7.1 assuming all other factors remain the same.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #3 of 6 Old 05-28-2013, 02:09 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
From a content standpoint ... Over the last two-to-three years 7.1 has become the default mix for feature films (including re-mastered editions of older movies). Most Blu-Rays will have a 7.1 mix. Older movies and DVD's will most likely be 5.1 or 2.0 mixes. (Almost no movies are natively mixed in 9.1, and 9.1 will probably be leap-frogged by a new format like Dolby Atmos, or something we haven't even heard of yet.)
But as flyng_fool said your room/seating is the primary factor ... If you have a small room, or the seating is against the back wall then 7.1 will be problematic and you won't lose anything using 5.1 (7.1 needs ample distance between the side-surrounds and the back-surrounds).
sdg4vfx is offline
post #4 of 6 Old 05-28-2013, 04:17 AM
Macstatic's Avatar
You basically asked 2 questions. If you're asking if adding a 2nd subwoofer will benefit your movie experience, YES. It might help even more than switching to 7 channels if your room is small (like the others said). If you have a receiver that has 7.1 capabilities, why not borrow some speakers from a friend to try it out and then if it sounds better to you then purchase 2 more speakers of your choice.
Like I said before, if you have 2 subs (even if they aren't the best out there) you will get a better bass response in the room, and better balance in the sound. Movies do really well with bass and having that presence or fullness helps more than having more channels.
For those looking into getting Energy speakers, or upgrading their current Energy setup, here are some reviews I've written that may help:http://www.tempestaudio.blogspot.com  (haven't updated in a while, but include Energy Take Classic 5.1, RC-10, CF-70, and CC-10)
Macstatic is offline
post #5 of 6 Old 05-29-2013, 08:06 PM
2013guy's Avatar
Hi, typically, what's the ideal distance between the sides and the back surrounds that would make the 7.1 work properly, can you elaborate please?
2013guy is offline
post #6 of 6 Old 05-30-2013, 09:07 AM
flickhtguru's Avatar
Liked: 110
3ft minimum distance behind the MLP for rear surrounds. My surrounds are directly to my sides and my rears are on the rear wall about 6ft behind me. I like that distance, its close enough that it still allows for seemless panning around the room, but its also far enough away that you can distinguish sounds between the side surrounds and the rear surrounds. If you are sitting up against the back wall the normal opinion is that rears are a waiste.
Shawn
flickhtguru is offline
Reply Speakers
