What are your favorite 2.1 speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-28-2013, 07:28 AM - Thread Starter
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
I went over to a Magnolia design center yesterday and was struck by an interesting thought while talking with the rep there. I asked his opinion between B&W, Sonus Faber, and Martin Logan which were the brands they had on display and he didn't give me a straight answer. Instead he categorized the speakers. He said that for HT his preferred B&W and for 2.1 he preferred Martin Logan. I'm a big B&W fan I've got two systems with their speakers, however I must say I was really impressed by both Sonus Faber and the Martin Logan's I listened to. They were both $10k speakers, but the Martin Logans' had a spatial quality that defied their positioning. They had them placed only about 3ft apart, yet sat me nearly 10 ft away. Obviously not an equilateral triangle, yet the sound stage and imaging were amazing. So on to my question Which speakers do you prefer for 2 channel listening and why?
Tweaked05 is offline
post #2 of 15 Old 05-28-2013, 07:44 AM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
I just bought a pair of Vandersteen Treo speakers, which are the best I have ever heard for under $10,000 (they cost $5950).
IMO they will blow away ANYTHING Martin-Logan makes, at any price. Some Sonus Faber speakers are pretty good, but you will dismiss them (anything under $15K, that is) once you have heard the Treos. I assume that you probably listened to the Cremona, which lists at $10K. Pretty good, but not great IMO.
I am running them with an Audio Research LS-26 preamp and a Bryston 3BSST2 amplifier, and the sound is to die for.
John Fort Audio in Richardson is your local Vandersteen dealer.
www.johnfortav.com
commsysman is offline
post #3 of 15 Old 05-28-2013, 07:53 AM
eljaycanuck's Avatar
Quoted: 1226 Post(s)
Liked: 1798
My old Paradigm 5se MkII / 7se speakers. They have a "laid-back", neutral to slightly "warm" sound, with clean highs, clear mids and a nice bottom end. Perfect with every kind of music. cool.gif
eljaycanuck is offline
post #4 of 15 Old 05-28-2013, 11:25 AM
65 Electra Glide's Avatar
Quoted: 78 Post(s)
Liked: 50
The NHT Xd system.
65 Electra Glide is offline
post #5 of 15 Old 05-28-2013, 11:46 AM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Originally Posted by 65 Electra Glide View Post
The NHT Xd system.
I was never lucky enough to hear this one, but everyone I know that had it or heard it was impressed.
Sad they decided to discontinue it.
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #6 of 15 Old 05-28-2013, 11:48 AM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
Magnepan 3.6 in a perfect room. I know I know it's the room. But it's the only one that stood out of all the speaker I've heard. I've heard many high end speakers in a non ideal rooms. I heard some that are close to it in non ideal rooms. Still searching and learning
datranz is offline
post #7 of 15 Old 05-28-2013, 11:59 AM
Reefdvr27's Avatar
Quoted: 1564 Post(s)
Liked: 1037
My pick would be the Vandersteen 3a Signiture or the Salk HT3.
Reefdvr27 is offline
post #8 of 15 Old 05-28-2013, 02:21 PM
Quoted: 78 Post(s)
Liked: 50
I was lucky enough to grab one of the last sets, if not the last set, at a price which I felt was a no-brainer, plus even added a second sub to the system. They obviously sound incredible, but they even look much better when you actually see them than what they appear in the pics.
post #9 of 15 Old 05-28-2013, 02:47 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Newform Research R630
kiwi2 is offline
post #10 of 15 Old 05-28-2013, 02:53 PM
astrallite's Avatar
Quoted: 24 Post(s)
Liked: 26
The NHT Xd clearance prices were crazy. The Xd had something like a $200 woofer and $100 tweeter per speaker (OEM) and the satellites were going for $100/each! O_O
astrallite is offline
post #11 of 15 Old 05-28-2013, 02:55 PM
LaoChe's Avatar
It depends on the room and the person. I have a friend with Martin Logan's and they sound great, however when off axis the SQ drops like a rock. IMO, if you have the choice between B&W, Sonus Faber and Martin Logan though, it's just a preference thing. What sounds best to you. At my Magnolia, I've had a sales rep state he liked the Sonus Faber's over the B&W's. I've also had another state he liked the B&W's over the Sonus Faber's, and didn't care for the Martin Logan's at all. And then you have Salk speakers that sound fantastic too. Quite honestly, if you had those choices, you really can't go wrong with any of them. Just demo them for yourself, and pick the one that sounds best to you. For me, I chose the B&W 805 Diamonds. Why? Because those are the size speakers that will work best in my room and they sounded fantastic when I demoed them. Yes, the B&W 800 Diamonds technically sound better, but they were out of my budget and also wouldn't even work in the room (way too big). So in short, first narrow down and select the speakers that work best in your room. Once you've done that, demo as many as you can to see which sounds best to you.
And sorry if I didn't sate this before, but my friend was using his ML in a 2.0 setup. I'm also using my B&W 805 Diamonds in 2.0. I'll later add a sub to cover the lower frequencies, but the 805's do a pretty dang good job of covering the lower frequencies for their size.
LaoChe is offline
post #12 of 15 Old 05-28-2013, 03:17 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
They were great components...but the tweeter was not $100(oem) according the SEAS rep.
-curtis
cschang is offline
post #13 of 15 Old 05-28-2013, 03:39 PM
tf1216's Avatar
What kind of room are you working with Tweaked05?
I was gifted extended listening time with the Sonus Faber Venere 3.0 at AXPONA this year. I thought they were wonderful sounding and my girlfriend thought they looked the part as well. For $3,500 they are on par with likes of the small boutique companies so many of us love. Their look might appeal to you more than those. It helped that the speakers were not close to any walls.
How close will your speakers be to your walls? What kind of music do you like to listen to?
tf1216 is offline
post #14 of 15 Old 05-29-2013, 12:34 PM
Quoted: 78 Post(s)
Liked: 50
IIRC, I vaguely seem to remember reading somewhere that the tweeter was basically the same version they had used for years going all the way back to the 3.3 and 2.9 models. The drivers, while probably great, are not what make this system special, it's the DEQX box which has been custom optimized specifically for them that gives them their "magic powers".
I need to get a Windows XP system to play around with changing the filters for dual subs since my Windows 7 computer apparently doesn't work with them. I also saw where somebody else basically posted the exact same problem on the NHT thread.
post #15 of 15 Old 05-29-2013, 12:48 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
I completely understand and agree.
It is the integration of those drivers is the real work. The great drivers certainly help.
At the 2005 CES (I think)...I saw/heard a demo on B&W 600 series bookshelves with and without DEQX. The difference was surprising!
-curtis
cschang is offline
Reply Speakers
