Behringer 2030P still the best $100 speaker? - Page 2 - AVS Forum
post #31 of 59 Old 01-01-2014, 10:12 PM
Skylinestar's Avatar
Quoted: 165 Post(s)
Liked: 68
Originally Posted by shadyJ View Post
I like my 2031ps but I would not use them to chase after reference sound. Remember they are intended for near-field use.
How about nearfield (3 feet) at reference level?.
Skylinestar is offline
post #32 of 59 Old 01-01-2014, 11:45 PM
shadyJ's Avatar
Quoted: 388 Post(s)
Liked: 603
At 3 feet I would think they could hit 105 dB peaks cleanly, so I believe so, yes.
shadyJ is offline
post #33 of 59 Old 01-02-2014, 08:15 AM
arnyk's Avatar
Quoted: 762 Post(s)
Liked: 1175
Originally Posted by JoeBloggz View Post
I'm considering The Behringers's(2030p) as well. I'm gonna wall mount my plasma and go with a 3.1 system for now. I already have a Polk subwoofer. I've read that matching L+R speakers with the same center is the best way to go. Do the 2030p's have an accompanying center? If not(I didn't see one) what would match them well for center channel? I'm considering the Marantz NR1403 for my receiver. Any other recommendations there? I'm looking to spend $400 or less on AVR.
The B2031'a seem to sound good when placed on their side, so they are their own center channel speaker.
Last night I was listening to a system with 9 2031As, all laying on their side. Sounded great. There were 2 massive subs, as well.
The claim is that that their unusually good dispersion (documented above) makes them far better speakers than most for mounting on their side.
arnyk is offline
post #34 of 59 Old 01-02-2014, 01:26 PM
krabapple's Avatar
Quoted: 174 Post(s)
Liked: 227
Originally Posted by krabapple View Post
Since I own a bunch of 2030Ps, I could, I suppose, dig out my multimeter, and measure DC resistance myself...crude measure compared to the graphed data above, but would it be sufficient to settle the matter?
Did this, applying the probes to the +/- rear posts, and the reading (analog) was 6 ohm, which I understand is normal for 8 ohm speakers measured this way. I don't own any 2031Ps for comparison.
krabapple is offline
post #35 of 59 Old 01-02-2014, 02:36 PM
Quoted: 165 Post(s)
Liked: 68
Is that a home theater setup? How far are the speakers from your listening position? What is the playback volume (#dB)?
post #36 of 59 Old 01-02-2014, 02:56 PM
shadyJ's Avatar
Quoted: 388 Post(s)
Liked: 603
Here is a measurement of the vertical off-axis for the 2031p, it doesn't look bad at all, although I wouldn't think it's as optimal as the horizontal off axis. Measurements are +15 degrees, 0 degrees, -15 degrees.
It would probably do fine, but likely not as good as its intended orientation.
shadyJ is offline
post #37 of 59 Old 01-02-2014, 05:05 PM
krabapple's Avatar
Quoted: 174 Post(s)
Liked: 227
Blue is 0, the other two -/+ 15? I imagine a 5dB dip in the 2k region could noticeable. Maybe DSP could fix?
post #38 of 59 Old 01-02-2014, 05:56 PM
shadyJ's Avatar
Quoted: 388 Post(s)
Liked: 603
I don't think DSP could do anything to fix that without making something else worse. If you were going to listen to this speaker on its side, you will want to be on axis. I have seen worse horizontal off-axis measurements though.
shadyJ is offline
post #39 of 59 Old 01-03-2014, 05:37 AM
arnyk's Avatar
Quoted: 762 Post(s)
Liked: 1175
Yes,
The front center is about 10 feet, and the front L&R are about 15 feet if memory serves. There are also 5 or 6 other speakers in surround duty over a similar range of distances. The system is used for both video and music.
With large system like this, whatever the listener's want! The two subwoofers each contain 2 ca. 15" JL audio drivers back-to-back powered by an amp farm on its own 230 volt 30 amp circuit, in the basement totaling out at 5 KW or so.
arnyk is offline
post #40 of 59 Old 01-03-2014, 05:42 AM
arnyk's Avatar
Quoted: 762 Post(s)
Liked: 1175
+1
Tell the truth I've seen many many on-axis response curves that were far worse. The speakers are soffit-mounted and not aimed down if I remember things right. The system is equalized for the desired response at the sweet spot with a combination of measured and listened-in tweaks. The owner has designed well-regarded consumer speaker systems with total sales of a few 100.000s.
arnyk is offline
post #41 of 59 Old 01-03-2014, 05:46 AM
arnyk's Avatar
Quoted: 762 Post(s)
Liked: 1175
The system's owner likes to yank my chain and criticize my use of center channel speakers for LCR, and my retort is "At least I'm using my speakers in their preferred orientation." His system sounds far better than mine. I'm fighting a losing battle because his listening room is large and conventional, and the walls in mine are about 40% glass.
arnyk is offline
post #42 of 59 Old 01-03-2014, 06:14 AM
tongliparty's Avatar
agree with you,You would have to go pretty nuts with them to cause actual problems. I would't want to run five of them on a entry level receiver at watch a movie at reference level.
67jnKg
tongliparty is offline
post #43 of 59 Old 01-03-2014, 07:27 AM
Quoted: 165 Post(s)
Liked: 68
Yes,
How old are those B2031A speakers? Are those Behringer amp (built-in inside speaker) reliable? I know active crossover is better than passive one...hence the B2031A sounds amazing to you, but I'm just worried about the reliability of the internal amp...especially when driven loud in movies with huge dynamics.
post #44 of 59 Old 01-03-2014, 11:19 AM
arnyk's Avatar
Quoted: 762 Post(s)
Liked: 1175
Yes,
Couple-three maybe 4 years. Remember, this is not my system so while I saw it go together my memory of it is not perfect.
Seems to be. I know a number of people who have bought them and recall no failures at all.
I believe there are internal power limiters fo some kind.
arnyk is offline
post #45 of 59 Old 01-03-2014, 12:59 PM
shadyJ's Avatar
Quoted: 388 Post(s)
Liked: 603
Behringer isn't known for reliability in electronics. I would go passive if you intend to drive your speakers hard.
shadyJ is offline
post #46 of 59 Old 01-03-2014, 01:15 PM
arnyk's Avatar
Quoted: 762 Post(s)
Liked: 1175
Yeah, sort of. Behringer uses contract manufacturing so different batches of a given model are made in different factories, but each batch comes from the same place.
Therefore there are good batches and bad batches and if you get a good batch or a product that has never run afoul of a bad factory you are good. The B203x seems to have been that way.
DCX 2496s, not so much! :-(
arnyk is offline
post #47 of 59 Old 01-04-2014, 03:35 PM
krabapple's Avatar
Quoted: 174 Post(s)
Liked: 227
I'm confused. Whose system does Shadyj's graph belong to? Whose system is Arny talking about?
post #48 of 59 Old 01-04-2014, 03:55 PM
shadyJ's Avatar
Quoted: 388 Post(s)
Liked: 603
That graph is from Zaph, it isn't from a system so much as it is a naked response.
shadyJ is offline
post #49 of 59 Old 01-05-2014, 03:55 AM
tubetwister's Avatar
Location: Sacramento delta N. Cal. US Don't trust any air I can't see ☺
Quoted: 626 Post(s)
Liked: 380
Originally Posted by Hifisound View Post
Did you get a chance to compare LSR308s with 2031s ?
Actually only by memory (and we all know reliable that is eek.gif ) they had the JBL's in the store and I have the 2031P's at home. I only listened to the Yamaha's and JBL's at the store . The max SPL mfr specification is the same btw.
Hard to say a shelf at Guitar center is a long way from a treated room my impression is the JBL's have a little more impact and clarity.
as did the even more expensive Yammies ofc both are powered also .The JBL's are Bi amped so I'm assuming no passive x overs .
IMO the Behringers are hard to beat in price range and better than most home speakers at least that I have heard for well over twice the money .
4 or five of those should make a lot of decent sound especially with some distributed bass ( 2 Subs ) I have 2 paired with 2 10" powered subs they are pretty good all in all they sound much better than the Pioneers or any tower speaker under a few hundred IMO. .
I didn't really look at the lie sheets that much the JBLs have a broader freq response according to the spec. I haven't seen any independent measurements good reviews though.
Hires Music formats ..............."Why does it sound like a CD ?" ............. can we make it louder "?
"The wireless music box has no commercial value. Who would pay for a message sent to nobody in particular?"
- David Sarnoff's associates at RCA the 1920's -
tubetwister is offline
post #50 of 59 Old 01-05-2014, 01:29 PM
Hifisound's Avatar
Thanks. Once you receive the LSR308s it would be an easy comparison at your place.
Btw , till few days back, the 308s were actually cheaper than 2031As on Amazon...
Hifisound is offline
post #51 of 59 Old 01-05-2014, 04:12 PM
Quoted: 626 Post(s)
Liked: 380
I will compare them I post back with my impressions and maybe write some sort or review and post it in the AVS review section as well.
keep us posted on your progress.
post #52 of 59 Old 01-05-2014, 08:37 PM - Thread Starter
alittletank's Avatar
As the OP I wish I could give a better review of these but my experience is so limited that I don't feel qualified. I have been using the 2030ps for my LCR for two years now and love the clarity and sound they produce. My room is 13x16.5 with DIY acoustic panels on the sides and rear of the room. I strongly feel that these are a great choice for a beginner who wants more than a HT in a box can provide.
Btw I drive them only with a refurbished Denon 2312CI
I look forward to a more trained ear review and hope that you post the link to the review here so I dont miss it. Thanks!
alittletank is offline
post #53 of 59 Old 01-09-2014, 11:44 PM
Hifisound's Avatar
I had got the following freq responses from SonicSense (http://www.sonicsense.com/blog/studio-monitors/studio-monitor-comparison#.Us-WUvQW18F) on a thread on http://www.gearslutz.com/
2031 : blue
JBL : orange
http://imgur.com/a/4xVnG
Though they are in room measurements in their room
post #54 of 59 Old 01-10-2014, 03:15 AM
krabapple's Avatar
Quoted: 174 Post(s)
Liked: 227
Are 2030P measurement graphs on the Internet anywhere for viewing?
post #55 of 59 Old 01-10-2014, 03:59 PM
arnyk's Avatar
Quoted: 762 Post(s)
Liked: 1175
Not that I know of. AFAIK the B2030 and B2031 tweeters are pretty much the same. The passive and active versions might be a little different as well.
arnyk is offline
post #56 of 59 Old 01-10-2014, 06:01 PM
shadyJ's Avatar
Quoted: 388 Post(s)
Liked: 603
There are measurements over at home theater shack. I'll be damned if I am going hunting for them right now though, but a couple google searches out to get you there. And yes, the 2030 and 2031 should be a lot alike. if anything the 2030 off axis FR might be a tad better as the 2031's larger woofer might not have quite as good dispersion higher up the frequency range. I doubt anyone would ever be able to tell the difference outside of the bass extension though.
shadyJ is offline
post #57 of 59 Old 01-11-2014, 12:42 PM
Hifisound's Avatar
Anybody listened to both 2031A and Yamaha HS8s ? I read that HS8s have a pretty flat freq response too..
post #58 of 59 Old 01-11-2014, 03:02 PM
FOH
FOH's Avatar
Quoted: 18 Post(s)
Liked: 213
Much good advice.
This area of small, prosumer monitors is such a high value, well vetted group, offering solid performance for the price. This market segment is so über competitive, us consumers win big time. Not just these inexpensive Behringers, but on up to the more expensive offerings like the Mackies, and others. Great stuff, pick the ones best suited to you.
A simple 2 channel system, or 2.1, 5.1, on up to a 7 channel multi-sub system, could be assembled with many of these quite easily ... with a nice coherence around channel to channel.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #59 of 59 Old 02-20-2014, 11:37 PM
Hifisound's Avatar
Anybody got to compare Behringer 103x with 203x series side by side ?
As per measurements here, 1031A is more flatter than 2031A
http://www.bonedo.de/artikel/einzelansicht/testmarathon-nahfeldmonitore-bis-1000-eur/2.html
Around 12 speakers compared here
Reply Speakers
Behringer Truth B2030p Passive Monitor , Dayton B652 6 1 2 2 Way Bookshelf Speaker Pair
Gear in this thread - B652 by PriceGrabber.com
