Need to upgrade my Home Theatre - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 06-01-2013, 11:40 AM
Dan Hitchman's Avatar
Quoted: 3417 Post(s)
Liked: 1773
Originally Posted by deids View Post
Ok, so lets say if i do not go with acoustic screen route at this time, can i still use the above setup ?
and if I go with the above setup, what receiver should i get, other than Pioneer SC-1522-k, as its a little expensive at this moment. Should i go with Pioneer SC-1222-k ?
Yes, you have placement flexibility by getting three identical CMT-340 SE mains, where you don't if you go with the horizontal CMT-340 SE C for your center speaker.
And again, with a weekend's DIY building project, you could easily add the frame and mount the AT screen... this really is the very best option and you should have room to do it. If I had the room I'd set one up in a heartbeat. smile.gif
Listen up, studios! Just say "NO" to DNR and EE!!
Dan Hitchman is online now
post #32 of 38 Old 06-02-2013, 10:35 AM - Thread Starter
deids's Avatar
Originally Posted by Dan Hitchman View Post
What he said: a little less power with the built-in amps on the 1222-k and it does up to 7.2 channels instead of up to 9.2 with the 1522-k. Don't wory about the .2 designation, most subs have built in plate amplifiers and receivers don't have those included. However, both receivers have pre-amp outputs allowing for the addition of more powerful amplifiers to drive your speakers if you want the extra oomph and clarity afforded by such amps.
What about the blu-ray player ?
I see there is a deal going on for Sony BDP-S590 in Newegg.
http://www.newegg.com/Product/Product.aspx?SID=jLmVnMuqEeKHVIqOGUSK0g0_4JAa3_0_0_0&AID=10440897&PID=1225267&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-cables-_-na-_-na&Item=N82E16882105670&cm_sp=
any idea about this one ?
Also there is Sony BDP-S185 for $45 on Newegg.
deids is offline
post #33 of 38 Old 06-02-2013, 05:40 PM
afrogt's Avatar
Quoted: 1097 Post(s)
Liked: 783
refurbished and out of stock on the Sony S590.
Afro GT
afrogt is online now
post #34 of 38 Old 06-03-2013, 07:56 AM
Liked: 1773
Looks like the new Sony BDP-S5100 is fairly decent. Has a lot of streaming app choices too. Some other brands skimp here. Like the Oppo players, this one also accepts Super Audio CD's for high res. music with multi-channel capabilities.
post #35 of 38 Old 06-07-2013, 07:50 AM - Thread Starter
deids's Avatar
What do you guys think of this :
Polk Audio PSW Series PSW505 12" Powered Subwoofer
Is it any good ?
deids is offline
post #36 of 38 Old 06-07-2013, 11:53 AM
Liked: 1773
Of the budget priced subs, this one is pretty darn good. Absolutely better than that particular Polk.
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780078
From time to time Newegg.com will have an even better sale, so you just have to get a price alert update (click the small button on the far right).
post #37 of 38 Old 06-07-2013, 01:27 PM - Thread Starter
deids's Avatar
I can't see any small button on the far right ? Is it on the above link ?
deids is offline
post #38 of 38 Old 06-07-2013, 01:36 PM - Thread Starter
deids's Avatar
Got it. It is with the Bell symbol says 'Price Alert'
deids is offline
Reply Speakers
Epson Powerlite Home Cinema 8500 Ub Lcd Projector V11h337020 , Pioneer Sc 1522k 9 2 Channel Av Receiver
