AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Speakers (http://www.avsforum.com/forum/89-speakers/)
-   -   TV stand that fits a 9" tall center speaker? (http://www.avsforum.com/forum/89-speakers/1475451-tv-stand-fits-9-tall-center-speaker.html)
DougReim 06-02-2013 11:24 AM
Hi,
I've been auditioning speakers for a couple of months and have decided on the Aperions. The problem is the center channel speaker is 9" tall and I can't find a TV stand that accommodates that height. My TV is a DLP that sits on top of the stand so I need an open style stand that has 9" of clearance on both the bottom and middle shelves to fit my AVR & center speaker. I've been searching and I can't find any stands that seem to do that.
Any suggestions for a stand that fits these larger center speakers?
I have seen the Standout cabinets and they would work but I like the open steel and glass style better.
bladerunner6 06-02-2013 12:16 PM
Originally Posted by DougReim View Post
Hi,
How about using something like this for the center?
http://www.crutchfield.com/S-5fYKkLtt0zl/shopsearch/Center_Stage.html
crn3371 06-02-2013 12:54 PM
+1
DougReim 06-02-2013 04:27 PM
Thanks for the suggestion but the strongest of those stands only supports 30 pounds and 6" deep. The Grand center is 39 pounds and 11" or 12" deep. Also with my set up the speaker would be too high. And most importantly, my TV feels really flimsy up top where that bracket would go. There's no strength in the top of my set, I'd be afraid the whole thing would come down.
Secret Squirrel 06-02-2013 04:54 PM
There is most likely not going to be an equipment rack that is going to fit your needs with a large center channel. I also had this problem with my large center channel. Most AV rack shelves wont be tall enough. You don't want the center channel down at knee level anyway.
I would suggest making a DIY riser for your center channel and TV. That's what I did. My center channel is at ear level and my TV sits on top of the riser. It's made out of schedule 40PVC and edge glued wood. It's extremely strong.
ElectroMike 06-02-2013 08:10 PM
Here you go, brown or white:
http://www.crutchfield.com/S-Mku1puJGHLR/p_6318137CWL/BDI-OLA-8137-Chocolate-Stained-Walnut.html
volfan dhp 06-02-2013 11:24 PM
Hey Doug, I had same problem with my VGC. I ended up removing middle shelf of my tv stand to fit mine. Of course I didn't want to change the stand I had. I did a quick search for tv stands on amazon and it looked like Bello had some. Checked their website and they have quite a few stands that should work. Check there, they have pics with measurements of shelf openings. Find the one you like and then check amazon for best price. Hope you find one that works for you.
bhaaf 06-03-2013 10:17 AM
Try Salamander Synergy.
DougReim 06-03-2013 02:05 PM
Really appreciate all the tips but so far.................
bhaaf: The Synergy has a center channel height of only 8.25", the Chameleon might work but it was over $2000 which is more than I want to spend plus it's enclosed which I'd rather avoid
volfan dhp: The Bello stands are exactly what I'm looking for but after 15 minutes on the phone with them, they realized they didn't make anything that had 9" clearance on the top and bottom shelves
ElectroMike: The height on that unit works but the center opening is only 20" wide where I need 26" and I wasn't crazy about that style or price, I should have mentioned that I'd like to keep the cost under $1000
Secret Squirrel (great screen name btw): I think I'm going to end up trying your idea, I'm not sure how good I can make that look but it looks like that's about my only affordable option at this point
Kisakuku 06-03-2013 02:32 PM
Here's what I ended up doing for my 11" x 23" x 12.5" center.
TheWind 06-03-2013 03:07 PM
From looking at your “TV Room Upgrade” pics:
Maybe another option might be to wall mount the TV so that its bottom is 9” (or more) above the top of you TV stand. Then just move the speaker up to the top shelf position.
DougReim 06-03-2013 04:15 PM
My TV is not a flatscreen but rather a DLP which doesn't lend itself to wall mounting. And I already have built a shelf in the wall behind the TV to hold lights and antennas.
Kisakuku 06-03-2013 04:30 PM
Yeah, I had a similar issue as I don't have a good anchor point for wall-mounting my TV. That's why I ended up modding my relatively inexpensive ($300 or so) TV stand.
DougReim 06-03-2013 04:50 PM
I saw that and it looks great. My stand has metal legs so that's not an option and I'm not particularly handy anyway.
volfan dhp 06-03-2013 05:57 PM
Hey Doug, wish I knew how to link these from my cell but I don't. Bello's website has at least three stands with openings big enough. Don't know which finish you got on your Grands but there is the AVSC2141 with a little wood on each side that would go well with the cherry. Amazon has it for a little over $200. One opening is 10 7/8" the other is 11". If you got black there is the PVS421HG that has 9 3/8" openings and is around $150 @ amazon. Both stands are rated to 125 lbs on top for tv. They say 46" but my tv is 55" and is on a stand made for 42" tv. The small amount of hangover doesn't look bad at all.
DougReim 06-03-2013 06:08 PM
volfan......thanks for your help, I'm surprised the Bello rep I talked to didn't mention the 2141. Although it won't work for me as it's only 44" wide and I need the stand to be between 60 & 70" wide, my TV is 73". I should have mentioned that in my original post. It looks like the 421 is only 33" wide so that won't work either but I appreciate it.
volfan dhp 06-03-2013 06:46 PM
Ok here's my last shot. Sonax B-051-LMT. 60" wide 10" openings. They have another model same width they say accommodates DLP's up to 82". BTW found all these suggestions with a google search for tv stands. Try it as you know better than I what you are looking for. BTW welcome to the Aperion family. I hope you like yours as much as I like mine.
Class A 06-03-2013 07:16 PM
I have a similar center a 9.25" high Aerial CC-3 center and Salamander proved to be a perfect solution. You can easily put these tables together to your personal specs.smile.gif
DougReim 06-03-2013 07:21 PM
volfan
Again, thanks.
I've been searching for a couple of hours today and also I looked around a few weeks ago when I first realized that whatever new center channel I end up with would not fit on my current stand.
You won't believe this but I had looked at that Sonax stand on my first go round. The between shelf dimensions from Sonax show 10" but the overall height says only 22" and some reviewers had posted comments saying that the website dimensions are wrong and that it only has 8.25" of clearance. If you roll over the image with the dimensions a window pops up saying "Actual height 8.25". That's been my luck with this search.
As for the Aperions, I've been auditioning the black bookshelves but I'm going to upgrade to the cherry towers. I'm really liking these speakers, the sound is growing on me instead of growing more fatiguing as other speakers have done. Beautiful cabinetry too!
DougReim 06-03-2013 07:25 PM
Class A
I was on the Salamander site earlier looking at the "Triple 20 with center channel shelf" but the dimensions show only 8.25" high for the center opening. What model do you have that fits your 9.25" tall speaker?
volfan dhp 06-04-2013 05:40 AM
According to a review I read on BB site the Sonax has proper space to fit the VGC. The guy said it was 8.5" to bottom of crossbar. He suggested installing components before putting in shelf above. Might be a bit of a pain to place and remove center but how often do you plan on doing that?
bjaurelio 06-04-2013 07:53 AM
I built a diy riser for my tv too. I used a couple of shelves from Lowe's plus screws and wood glue.
Kisakuku 06-04-2013 08:02 AM
That makes sense; my Sonax stand is like that too (about 1.5" of clearance behind the horizontal support bar). However, there's a bigger issue than just ease of installation. Ideally, the center should stick out at least an inch beyond the front edge rather than be behind a bar that would create some unwanted reflections.
DougReim 06-04-2013 08:15 AM
volfan,
Are you saying that you have to place the speaker rearwards somewhat so that the brace doesn't interfere? If so, I don't want to go that way because of reflection. With the overall height being 22" it's hard to see how they can have that much clearance between the shelves.
With that being said, I like this stand so I'm going to call Amazon and see if they can verify the dimensions.
Here's a link to the page that shows the 8.25" clear height when you roll your mouse over the dimensions.
http://www.amazon.com/gp/customer-media/product-gallery/B0071IMNYA/ref=cm_ciu_pdp_images_1?ie=UTF8&index=1
In the meantime, I'm having my shop guy make a riser so I'll see how that turns out.
bhaaf 06-04-2013 09:38 AM
On the Salamander Synergy all of the shelves are adjustable up and down. There not cheap but they are very nicely made. I have the triple 20.
DougReim 06-04-2013 09:52 AM
bhaff,
I agree they look nice.
If I'm reading correctly the triple 20 is not wide enough to fit a 26" cc speaker and the triple 20 with cc design is only 8.5" tall and isn't adjustable?
From Salamander's site:
Includes 1 fixed, triple-width shelf and 3 rear panels.
Holds TV's or DLP's up to 70
Accommodates S20 Side Panels and S10 Doors.
Measures: 65.75" W x 19.75" D (ID= 19.75" W x 18" D) leveler feet allow maximum height of 21". Center channel opening: 62" W x 8.125" H x 17.5" D.
thrand1 06-04-2013 10:38 AM
bhaff,
I think what bhaff is referring to is the fact that you can get risers made to your specified height. These "risers" are basically another shelf but without any posts running across the front of it- a metallic "header" bar of sorts runs across the top to provide support. You can order a custom size from 8.5" to 17". Go an inch bigger than suggested as that metal header takes away about half an inch of clearance in the opening. Here's a link to a page with an example, look for the words "Triple Riser." I purchased an 11" riser shelf for my 9.5" tall center channel and it works very well as it is unobstructed by any support bars, and I still have my heavy plasma TV (>100lbs) on the top.
DougReim 06-04-2013 11:51 AM
thrand1,
Got it, thanks. I didn't see the custom section before. This is more than I wanted to spend just to accommodate a speaker but it does work. I'll see how this riser that my shop is making turns out and if it looks ******, I'll probably get one of these Salamanders.
Thanks guys, I really appreciate all the suggestions.
DougReim 06-04-2013 12:17 PM
If anyone is interested, I just found this which looks perfect. I called and they're going to verify the dimensions and get back to me. It's probably not quite as nice as the Salamander but it's about $600-$700 cheaper.
http://www.theaterseatstore.com/furnitech-ft72ccb-e
Drumcorps77 09-12-2014 11:16 AM
Originally Posted by DougReim (Post 23386507)
Really appreciate all the tips but so far.................<br><br>
bhaaf: The Synergy has a center channel height of only 8.25", the Chameleon might work but it was over $2000 which is more than I want to spend plus it's enclosed which I'd rather avoid<br>
volfan dhp: The Bello stands are exactly what I'm looking for but after 15 minutes on the phone with them, they realized they didn't make anything that had 9" clearance on the top and bottom shelves<br>
ElectroMike: The height on that unit works but the center opening is only 20" wide where I need 26" and I wasn't crazy about that style or price, I should have mentioned that I'd like to keep the cost under $1000<br>
I have the same exact dilemma polk csia6 huge center speaker no tv,monitor risers will fit :( I've been searching for weeks:mad:
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
