How big are large cinemas front speakers? - AVS Forum | Home Theater Discussions And Reviews
Old 06-06-2013, 07:12 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Last week i saw hangover 3 at the largest cinema in Malta which seats over 700 people and is the only cinema in Malta to be equipped with full T.H.X approved sound.
I saw all the side and rear speakers , but for the fronts and sub, they must be behind the screen or something.
I was wondering , how big are the fronts for a cinema like this ? And what sub ?
dazkyl is offline
Old 06-06-2013, 07:20 AM
MKtheater's Avatar
Quoted: 1589 Post(s)
Liked: 1116
Yes they are big and depends which speakers on how big. They use many subs and if THX approved probably rated to 22-25hz with great output at 30hz and above.
Marantz 7702 Atmos
MKtheater is online now
Old 06-06-2013, 07:23 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
I thought so that they use more than 1 sub in such large cinema rooms. Can you show me such subwoofer rated @ 22-25hz ? Arents there home subs out there that goes below 22hz ? :O
dazkyl is offline
Old 06-06-2013, 07:34 AM
MKtheater's Avatar
Liked: 1116
Of course but our rooms are tiny in comparison. The theaters need loud SPL's to fill that room so they cut off the low end at around 30hz and 20hz in the best cinemas. This also stops the lower frequencies from bleeding to the next cinema which as you know still bleeds. It would be much worse with the lower stuff. Do you know which brand of surrounds they used? JBL, Klipsch, etc..
Marantz 7702 Atmos
Old 06-06-2013, 06:18 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
I bet Dazkyl could go into the theater where he saw the movie and ask them what speakers/subs they use.....
Then he would know for sure instead of us speculating.
Afro GT
afrogt is offline
Old 06-11-2013, 02:44 AM
keyboardcat's Avatar
I used to work at a movie theater. it was a older theater so they had big 18 and 20 inch subs behind the screen. the smaller theaters I think the projection guy told me two altec lansing 15 inch subs. I took two of them home after they threw some away when new ones came in, but never ended up doing anything with them so I gave them away. the ones I took home was just the box and a huge horn tweeter on the top and the crossover on the back. the speaker box that i took home said altec lansing. I remember some of the big subs in the larger theaters were peavey. I saw one of the subs in just the box in the projection room and it was 18 inches. when they tore the old theater down and built a new one I heard that they were using christy amps. i am not sure what speakers for the new theater though.
keyboardcat is offline
Old 06-11-2013, 02:45 AM
mk in the old days did a lot of theaters use the cheap stuff like peavey? I remember peavey and altec lansing in most of the 12 movie rooms where I used to work.
Old 06-11-2013, 07:03 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Did what you gave away look like any of these?
psgcdn is offline
Old 06-11-2013, 07:29 AM
Bill Fitzmaurice's Avatar
Liked: 4631
Bill Fitzmaurice is offline
Old 06-11-2013, 09:13 AM
adupree's Avatar
You see a lot of Danley Sound Labs and EAW
Ignorance is a choice
adupree is offline
Old 06-11-2013, 01:41 PM
Mrkazador's Avatar
Quoted: 252 Post(s)
Liked: 378
I don't know what theaters are using these days but this will give you an idea how big/small they can get
http://www.qscaudio.com/products/speakers/dcs/dcs.htm
http://www.jblpro.com/products/cinema/index.html
Mrkazador is offline
Old 06-11-2013, 07:15 PM
bill if you were closer where i used to live and wanted them I would have let you have them for free back then. A workers boyfriend put them in his truck to get them home. I tried to get one in the car later on and it wouldn't go so I never got to take it to a stereo store to have them looked at. they sat in my backyard in the carport for a long time until someone asked if he could have them for his church. I used to live in kentucky and worked for cinemark. they did look like the pics but I think a little bigger. I was a usher and cleaned the movies and tore tickets.
