4 15" - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 06-09-2013, 07:59 AM
Bill Fitzmaurice's Avatar
Liked: 4831
There's an old saying that you can't polish a turd. Actually, you can. But who wants a polished turd?
You might be able to get them sounding better with EQ, but they'll never sound as good as a nice pair of bookshelves and real subs.
Bill Fitzmaurice is online now
Old 06-09-2013, 08:06 AM - Thread Starter
chet1185's Avatar
Ok then...let's change this up now. What speaker types should I look into to go with my receiver?
chet1185 is offline
Old 06-09-2013, 08:55 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It depends more on your room size and what you're intended use is. Movies or music?
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 06-09-2013, 09:04 AM - Thread Starter
chet1185's Avatar
Both. But more for TV and movies. This sounds really good now for it , so can I just add a powered woofer? I had one but it just stopped working. What should I look for?
chet1185 is offline
Old 06-09-2013, 10:30 AM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Originally Posted by chet1185 View Post
Kind of surprising to see a 2nd order electric crossover in there, if these are white van speakers. Probably just using textbook values, and I dont see an extra coil to knock the lower woofer down, so just a straight 2 way.
Seems like a generic PA/DJ speaker.
Jay1 is offline
Old 06-09-2013, 12:08 PM
donutfan's Avatar
Quoted: 18 Post(s)
The crossovers aren't *too* bad quality-wise: the inductors (i.e. coils) are of the air-core type and it seems the capacitors are non-electrolytic.
Btw I've seen power meters before on some older speakers back in the 80s.
donutfan is offline
Old 06-09-2013, 12:32 PM
Reefdvr27's Avatar
Quoted: 1566 Post(s)
Liked: 1045
I looked these up and cannot find anything other than pictures. They are supposedly a DJ speaker.
Reefdvr27 is offline
Old 06-16-2013, 11:11 AM - Thread Starter
chet1185's Avatar
What kind of powered subwoofer do you hook up to the subwoofer out on the receiver? I'm seeing allot of them but none look like the one I have. The one I have only has a power cord and a level knob, and a single input for a subwoofer cable.
chet1185 is offline
Old 06-16-2013, 12:51 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The sub you have will work just fine with your receiver. You have a singe sub out on the back middle top of your receiver. Hook one end of the sub cable to that, and ten hok the other to the input of your sub. Plug your sub into the wall, run MCACC and you're done.
Old 06-16-2013, 12:53 PM - Thread Starter
chet1185's Avatar
The sub I have doesn't power on anymore, that's why i'm asking what sub to get. I see allot with multiple hook UPS in the back when mine only had one. I don't know how they hook up. I am thinking about just getting a Sony sa-w2500. How do I hook that up?
chet1185 is offline
Old 06-16-2013, 01:26 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It doesn't matter that it has more than one input. You can just pick one or the other input, or get Y adapter and use both. That Sony sub is a piece of junk. Can you afford a Klipsch RW-12D?
http://www.supplysale.com/Item.aspx?sku=0053543063OP&sgd=321d319d314d316d319&zmam=63922997&zmas=1&zmac=4&zmap=0053543063OP&gclid=CPGd_Z6n6bcCFZBj7Aod2zAA6w
Old 06-16-2013, 02:37 PM - Thread Starter
chet1185's Avatar
Definitely not. And I would never spend that much on one anyway. Maybe if I listened to it all the time instead of just occasionally. Got a cheaper idea?
chet1185 is offline
Old 06-16-2013, 04:05 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629
http://www.newegg.com/Product/Product.aspx?Item=N82E16882007034
Jay1 is offline
Old 06-16-2013, 04:45 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
The Dayton Audio sub is a great one for the price.
Old 06-17-2013, 01:00 AM - Thread Starter
chet1185's Avatar
That Dayton is nice. Is theater solutions any good?
chet1185 is offline
Old 06-17-2013, 01:03 AM - Thread Starter
chet1185's Avatar
Anyone know what would cause my pioneer sub to not power on? Wall outlet works, fuse inside is good.
chet1185 is offline
Old 06-17-2013, 06:08 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
It could be any number of things. It may have another fuse inside where you'd have to remove the amp to get to it.
Old 06-19-2013, 04:02 PM - Thread Starter
chet1185's Avatar
Anyone have that Dayton sub? I'm leaning towards that and wanna know from some people who may have one or heard on, how good it is.
chet1185 is offline
Old 06-19-2013, 07:43 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Do a search, you'll find a lot on it.
Old 06-20-2013, 06:17 PM - Thread Starter
chet1185's Avatar
How is that 8" and 10"Dayton sub? The woman is not a big fan of allot of bass, so I think the 12"will be to much
chet1185 is offline
Old 06-20-2013, 09:24 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
You can always turn it down if its too much bass. But if its not enough then you're stuck. I would err on the side of getting the bigger sub and just turning it down.
Pioneer Vsx D514 Multi Channel Digital A V Receiver
