Suggestion for surround side & rear speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-10-2013, 09:11 AM - Thread Starter
johnlo's Avatar
I need some help. This is gonna be a 7.1 setup. I'm looking for some surround side and rear speakers that needs to be hang on wall/ my front speakers are Pioneer SP-FS52. the room is about 12'x16'. behind the couch, I have about 4' space to the wall. I am planning on to get the Klipsch KS-14 as my side and rear. Should I go with the Klipsch RS-41 II which is a bit better? What match better with the Pioneer?
TIA.
john
johnlo is offline
post #2 of 12 Old 06-12-2013, 08:24 AM - Thread Starter
johnlo's Avatar
anyone?!?!
johnlo is offline
post #3 of 12 Old 06-12-2013, 09:41 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
... I'm looking for some surround side and rear speakers that needs to be hang on wall/ my front speakers are Pioneer SP-FS52. ... What match better with the Pioneer?
SP-BS22-LR speakers. The Klipsch speakers are likely to have a sound that is too different from that of your mains + CC speaker.
eljaycanuck is offline
post #4 of 12 Old 06-12-2013, 09:48 AM
flickhtguru's Avatar
Liked: 110
+1 get the matching Pioneer bookshelf speakers.
Shawn
flickhtguru is offline
post #5 of 12 Old 06-12-2013, 10:10 AM - Thread Starter
johnlo's Avatar
ic. i was somewhat afraid of that. when do you have something else you can suggest that's also easy to hang on wall?
johnlo is offline
post #6 of 12 Old 06-12-2013, 11:17 AM
Liked: 110
Why don't you want the Pioneers?
Shawn
post #7 of 12 Old 06-12-2013, 11:22 AM - Thread Starter
johnlo's Avatar
hangin on the wall... would have to gt a bracket. and i'm not sure if i can do it. plus my left side is a door. only have 1 ft on top door to hang anything.
johnlo is offline
post #8 of 12 Old 06-12-2013, 05:01 PM - Thread Starter
johnlo's Avatar
after some more searching and reading. how would the Polk OWM3 sound with the Pioneer SP-FS52 front?
johnlo is offline
post #9 of 12 Old 06-12-2013, 05:45 PM
DaveCarrera4's Avatar
Try to use the Pioneer BS22's if at all possible for timbre match. I have 2 hanging from the wall (front height) and 2 on a tall stand (rear surrounds).
Why go out to a movie theater?
DaveCarrera4 is offline
post #10 of 12 Old 06-12-2013, 05:53 PM - Thread Starter
johnlo's Avatar
Tomorrow we are closing on the home. So after that I will have some time to check out the room that the TV will be in. yes I am hoping too. I'm sure I can come up with something. I do like the Polk as far as design goes.
What type of bracket are you using to hang the BS22?
johnlo is offline
post #11 of 12 Old 06-13-2013, 05:57 AM
Made the part on the wall from deck hangers, double joist I guess. Painted flat black. Added a screw with double nuts to hang speakers on. Then I screwed the hanger clips onto back of speakers. I'm in Finland, or I'd take pictures to show you. I also bought inexpensive gimbal speaker mounts from Monoprice, and should switch them over. They were under $6 and look really well built, http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10828&cs_id=1082804&p_id=3012&seq=1&format=2
post #12 of 12 Old 06-14-2013, 05:50 AM - Thread Starter
johnlo's Avatar
Well after lookin at the new home theatre room. I gonna put the TV differently and not sure if 7.1 would be possible. The couch will be against the wall now. But hanging the side surround wouldn't be a problem now. Need to rethink all this again.
johnlo is offline
Reply Speakers
