$1,000 budget - AVS Forum | Home Theater Discussions And Reviews
Old 06-12-2013, 07:42 AM - Thread Starter
nemoET's Avatar
Hello,
Basically, I'm looking to spend about $1,000 after taxes on a full 5.1 speaker setup and am looking for recommendations.
Some things to know:
I'm in Canada
Receiver - Yamaha RX-V773
Current speakers - Pioneer S-HS100
I've done some research and looked around but I haven't been sold on anything.
nemoET is offline
Old 06-12-2013, 08:21 AM
Louquid's Avatar
Liked: 38
Originally Posted by nemoET View Post
Hello,
I'm in Canada
Are you just looking for speakers and a sub, or are you also wanting to buy the receiver with this budget?
Louquid is offline
Old 06-24-2013, 01:38 PM - Thread Starter
nemoET's Avatar
Already have the receiver. The $1000 budget is for the speakers and sub alone.
nemoET is offline
Old 06-24-2013, 09:11 PM
Elihawk's Avatar
Quoted: 1015 Post(s)
Liked: 860
One suggestion ascend acoust 170s and cmt340 center, a rw12 klipsch sub and a pair of cheaper surrounds.
Also, the Pioneer AJ speakers are always recommended as good speakers for the buck!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
Old 06-24-2013, 11:40 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
+1
The 170s are awsome bookshelf speakers I don't think u can beat for the priced. And I have the 340 center and IV been more than happy. I used to run 170s as mains, I pared em with little deftech pro monitor 600 for surrounds and it actually worked very nicely.
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is online now
Old 06-25-2013, 04:25 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Hello,
I'm in Canada
Take a look at Infinity's Primus line of speakers, particularly the bookshelves, center, and floor standers.
I recently picked up a pair of 363s and a 351 center for $200 each at Amazon. I've previously used 163s in a different system. There are good technical reviews of several of these speakers in Stereophile.
Another somewhat smaller but said to be very good line of speakers is the Andrew Jones "famous designer" series from Pioneer.
For subwoofers, the BIC Acoustech PL 200, the BIC America F12, and the Polk SW-505 are highly rated low end subwoofers.
arnyk is offline
Old 06-25-2013, 04:40 AM
Bond 007's Avatar
Quoted: 2372 Post(s)
Liked: 1907
No offense but Canada really throws a wrench into things. What size is the room? Since youve already done some research try listing what is available to you.
Licence to Kill
Bond 007 is online now
Old 06-25-2013, 04:54 AM
Bond 007's Avatar
Liked: 1907
Old 06-25-2013, 04:56 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
arnyk is offline
Old 06-25-2013, 05:00 AM
Bond 007's Avatar
Liked: 1907
My things. Canada always limits options and makes things more expensive. Not sure if acousticsounddesign.com will even deliver to Canada.
Licence to Kill
Old 06-25-2013, 05:12 AM
Bond 007's Avatar
Liked: 1907
http://www.acousticsounddesign.com/core/view_BigProduct.cfm?pid=1540&sc=27
Call or email these guys and see if you can get this delivered to Canada with the PL200 for $999. It will easily outperform anything else listed here imo. and the 773 will have no problems driving it.
Licence to Kill
Old 06-26-2013, 12:59 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
You might consider putting your budget into three front speaker LCR and a sub. That way you would be getting better quality speakers on the speakers that affect the sound the most.
You could use the two best speakers from your current system (probably the LR front mains) as surrounds. (Then maybe upgrade the surrounds later if you feel you need to.)
sdg4vfx is online now
Old 06-26-2013, 09:55 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Set of NHT absolute zeros (5) and a sub.
lespurgeon is offline
