Ascend vs Arx for LCR setup - AVS Forum | Home Theater Discussions And Reviews
Old 06-12-2013, 05:23 PM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
Hi All,
I am looking to upgrade my front speakers with some bookshelves. I am torn between Ascend or Arx bookshelves
Here is what I am looking at:
Ascend:
L/R: 2 x CBM-170SE
Center: CMT-340SE
Arx:
L/C/R: A1b
These will be powered by a Denon AVR-790 which does 90W per channel. I already have some in-ceiling surrounds. I do not have a sub at the moment but will be looking to get a BIC F12 or SVS sub when either goes on sale. These speakers will be in my living room area which is roughly 15'x20'. I have an open floor plan so my kitchen opens up to the living room.
utee05 is offline
Old 06-13-2013, 08:21 AM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
I mainly watch tv shows and blu-ray rips with the occasional music listening. I attached a pic of my temp setup.
utee05 is offline
Old 06-13-2013, 09:51 AM
gtpsuper24's Avatar
Liked: 99
Only a couple of users has demo'd both the Ascend and the Arx together. I'm a fan of the Arx and have been extremely happy with them, very well built, awesome woofers and planar ribbon, crossover quality is top notch especially for this price range and has a nice large soundstage.
In the end you can't go wrong with either, but have similar traits and neither really one ups the other in any subjective category.
gtpsuper24 is offline
Old 06-13-2013, 10:58 AM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
Thanks for the feedback. At the current moment the Arx set is cheaper than the Ascend setup so that is another thing that is helping me lean more towards Arx at the moment. I have heard nothing but good things about both brands so I figured I really can't go wrong.
utee05 is offline
Old 06-13-2013, 11:58 AM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Do you plan on placing the speakers into the same locations as your current speakers?
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
Old 06-13-2013, 12:00 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
After hearing both side by side couple of months ago, I definitely would not say they have similar traits.
-curtis
cschang is offline
Old 06-13-2013, 12:19 PM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
I will be placing the center channel in the same location as my current center speaker. The left and right will be mounted on the wall using some wall mounts along the side of the tv along the 2 column areas and have them aim downwards towards the seating area.
Which ones did you like better?
utee05 is offline
Old 06-13-2013, 12:37 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
You really need to take into consideration the rear port of the speakers. You will not be able to get either speaker up against the wall like you have your current center. Also, being so close to the sidewall will not be good for any speaker.
My observations/opinions....I think Arx has deeper bass, but the Ascend is punchier. The midrange on the Ascend sounded a bit more open and forward to me, and the Arx a bit laid back. I felt the treble on the Arx was a bit more extended, but Ascend had more detail, especially in the lower treble...probably around the crossover area. The Arx seemed to have a wider soundstage, while the Ascend imaged better.
You should take advantage of the trial periods and compare both for yourself. I think that would be the smartest thing to do. Also, before ordering any speakers, investigate your mounting options (actual wallmounting hardware and center positioning).
-curtis
cschang is offline
Old 06-13-2013, 01:34 PM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
The circles mark where the right and left speakers will be mounted.
I will be looking to get these mounts to get the speakers a bit away from the wall:
Pinpoint Wall mounts
For the center channel I would probably make a shelf with L-brackets and rest the speaker on there. I know that the Arx come with a plug for the port so that would be an option though the center speaker is something I need to think about more on how I would mount that depending on which setup I choose.
utee05 is offline
Old 06-13-2013, 01:59 PM
Billy p's Avatar
Quoted: 300 Post(s)
Liked: 662
Hi OP...I know Curtis gave you a honest response but you might want to consider some of his Wave Crest Audio speakers....they're front ported unlike the aforementioned & might work better in your situation. WCA speakers are designed fully by Ascend Acoustics...I know Curtis, would gladly answer questions you have regarding any Ascend products or WCA speakers which BTW...come with free shipping at this time.
Ascend Acoustics Towers: STC w RAAL, 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo BDP-103D,
Apple TV+ Giga 1800
Sub FA 18: (Santos RW)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
Old 06-13-2013, 02:00 PM
Jon Lane's Avatar
Quoted: 94 Post(s)
Liked: 373
utee05, the Arx may be used close to boundaries by installing the foam port plugs (no charge). This option is discussed in the User Guide and converts the bass system from bass reflex to well-damped acoustic suspension. Bass is attenuated sooner but has a slower rollout. This option opens up new placement options.
Remember that opinions will come from a variety of motivations and your ears-on experience should always trump them.
If we can help with your setup, please don't hesitate to contact me personally.
Jon Lane is offline
Old 06-13-2013, 02:19 PM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
Thanks all for the response. I agree my situation is not ideal for rear ported speakers and I had looked at WCA speakers but felt that for a bit more I could get a bit better sound from the CBMs and CMT speakers.
Thanks for the reminder on the Arx pprt plugs that you can put in for the speakers.
For rear ported speakers how much space is suggested to have between the rear port and a wall?
utee05 is offline
Old 06-13-2013, 02:29 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
I believe Ascend has port plugs available as well. You just need to call them. But be aware, that any speaker that is designed with a port, and then you seal it with a plug, it will cause a slight rise in bass response before it is attenuated. Not usually a big deal, but it does change the characteristic of the speaker.
The recommended clearance distance for the 170SE is 3" or so. I don't know about the Arx, perhaps Jon or gtp can answer. But if you are crossing them to a sub well enough above the port's tuning, then a speakers port output doesn't come into play much, and you can place them closer to the wall. It is something to experiment with.
-curtis
cschang is offline
Old 06-13-2013, 02:38 PM
Jon Lane's Avatar
Quoted: 94 Post(s)
Liked: 373
In general ports need little clearance to do their job but since the speakers they're in are frequently designed for fairly unrestricted use, a speaker may be best suited by moving it from the walls. The A1b is a 5.25"-based system, and when converted to sealed operation gets along well in closer quarters.
Edit: Converting the A1b to sealed does not actually lift the midbass. It overdamps the bass a little, easing room loading and subwoofer integration.
Jon Lane is offline
Old 06-13-2013, 02:39 PM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
Ok thanks for the info. In my case since I will be angling the L/R speakers then I should get the 3" space from the wall. I guess my only currently issue will be the center channel speaker. I could probably cross this above the port's tuning as you mentioned to allow me to put it much closer to the wall.
Thanks again for all the info, very helpful.
utee05 is offline
Old 06-13-2013, 02:46 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
If you cross at 80hz (which is pretty standard) then you will probably be far enough away from the port tuning on each speaker.
I am more concerned about the proximity to that right sidewall, but probably not much you can do about that.
-curtis
cschang is offline
Old 06-13-2013, 03:43 PM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
Yup can't do much about that right side wall. That darn fireplace is on that wall and don't know why builders put fireplaces in homes in Texas.
Guess I will get the mounts and see what I have to work with.
utee05 is offline
Old 06-14-2013, 08:47 AM - Thread Starter
utee05's Avatar
Quoted: 30 Post(s)
Well I found some B-stock of the Arx1b so I will be getting those. That made my decision easier. Also ordered my wall mounts as well.
For using the Arx1b as a center is it best to place it horizontally or vertically?
utee05 is offline
Old 06-14-2013, 09:21 AM
padgman1's Avatar
Vertically if you can....you can rotate the tweeter if the speaker is horizontal..........
padgman1 is offline
Denon Avr790 7 1 Channel Multi Zone Home Theater Receiver With 1080p Hdmi Connectivity , Ascend Acoustics Cbm 170 Se , Ascend Acoustics Cmt 340 Se Center , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
