$1k budget for speakers & sub. any recommendations??? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 06-13-2013, 02:09 PM - Thread Starter
cjp3's Avatar
cel4145,
im just looking for the best bang for my buck. i havent bought any audio equipment in about ten yrs so im really out of the loop. but after hearing back from so many people i dont think 1k will be enough for a new quality 5.1 speaker system. so i think i might have to up my budget to around $1500, id really hate to spend more then that rt now.
cjp3 is offline
post #32 of 38 Old 06-13-2013, 03:58 PM
padgman1's Avatar
Originally Posted by cjp3 View Post
padgman1,
how about
2 pair of b-stock htm-200se & 1 htm 200se center
for $570
The HTM- 200 SEs will not be enough of a quality and power ( loudness) upgrade.
Cel's post right above this one would be a great purchase.........if you absolutely need 5.1 right now. Otherwise, I would concentrate on 3.1 ( what I suggeested, which is only a 340SE change for the center from what cel suggested) and add the 200's ( or another pair of either 170SE's for surrounds or a pair of 340SE's for the main and moving the 170SE's to surrounds) later..........
padgman1 is offline
post #33 of 38 Old 06-13-2013, 04:05 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
cel4145,
I think if you were able to push your budget up to say $1500 you could get yourself a great little 5.1 system that would keep you happy for another 10 years.
jbrown15 is offline
post #34 of 38 Old 06-13-2013, 04:24 PM
cel4145's Avatar
Quoted: 2662 Post(s)
Liked: 2993
cel4145,
In that case, I would go with the CBM-170 SE for left/right, CMT-340 SE center, HTM-200 SE for rear, and then the Rythmik LV12R. Or you might look at the HSU Hybrid 2 5.1 package.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #35 of 38 Old 06-13-2013, 04:54 PM
Kini62's Avatar
Quoted: 1472 Post(s)
Liked: 1351
IMO using speakers such as the RB41II for LR and C not working depends on how far you sit from them regardless of room size. Room size definitely comes into play with the sub though.
If your main LP is 9-12 ft or so from the front stage then 4" speakers can work well. I use 5 NHT SuperZero 2s with a 50 watt/channel AVR and can hit the upper 90dbs at LP (about 9-10ft) during HT use. My room is small and can be sealed but I don't think that matters for anything other than bass response.
Also, a good sub like the LVR12 would have no problem integrating with speakers crossed at 100hz.
That said, a set of 5 NHT Superzeros would be a better sounding choice than the Klipsch if you plan on any music listening.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #36 of 38 Old 08-01-2013, 08:17 AM
ccurryman's Avatar
My 5.1 Klipsch system is for sale at a very reasonable price if you are interested...
http://www.avsforum.com/t/1482769/klipsch-home-theater-speaker-system-rb-41-ii
Let me know..
ccurryman is offline
post #37 of 38 Old 08-01-2013, 09:36 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
AcuDefTechGuy is offline
post #38 of 38 Old 08-01-2013, 11:45 AM
shanewu's Avatar
I have a Hsu sub and am very happy with it so I'd look at Hsu package deals and take a look at Aperion Audio speakers as well for good bang for the buck.
shanewu is offline
Reply Speakers
Onkyo Tx Nr414 , Klipsch Rb 41 Ii Bookshelf Speaker
