Need assistance with shopping 2.1 home theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 06-13-2013, 12:29 AM - Thread Starter
snakzz's Avatar
Heisan,
Have just purchased a Panasonic 60 "DT60 LCD TV, so now I need a home theather that can complement this.
I intend to connect an PS4, the TV, Bluerayplayer and what else I could have on the bench to it.
I do not like having cables being pulled across the floor back to the living room, so that's why I'm basically looking for 2.1 home theater system.
I plan to provide up to 1200 dollars, no more of this if it is something special.
I have currently seen at these:
1.
Harman/Kardon 2.1 home theatre BDS 470
http://www.elkjop.no/product/tv-lyd-og-bilde/hjemmekino/HKBDS470/harman-kardon-2-1-hjemmekino-bds-470
2
Sony 2.1 home theatre system BDV-NF720
http://www.elkjop.no/product/tv-lyd-og-bilde/hjemmekino/BDVNF720/sony-2-1-home-theatre-system-bdv-nf720
3
Or possibly create a combo with:
Bose CineMate GS
http://www.lefdal.com/product/tv-lyd-bilde/hjemmekino/BOSECINEMGS/bose-cinemate-gs
and
3D Blu-ray player BDP-S5100
http://www.lefdal.com/product/tv-lyd-bilde/dvd-bluray-barbar-dvd/BDPS5100B/sony-3d-blu-ray-spiller-bdp-s5100¨
What do you think?
Have you or any other tips?
snakzz is offline
post #2 of 18 Old 06-13-2013, 03:27 AM
coytee's Avatar
Quoted: 209 Post(s)
Liked: 350
Take your $1,200 and look for some used (and probably nicked up) LaScalas.  Use those for the first 3-4 years while you save up for a Danley DTS-10 sub and never look back.
coytee is online now
post #3 of 18 Old 06-13-2013, 04:15 AM
Elihawk's Avatar
Quoted: 1313 Post(s)
Liked: 1144
The Bose cinemate is not just bad, it is brutal. Just a blast of crappy midrange!
For 1200 dollars, you could get a pair of ascend acoust cmt340, 500 dollars, a klipch rw12 sub and any number of decent AVRs...
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #4 of 18 Old 06-13-2013, 04:36 AM - Thread Starter
snakzz's Avatar
I am looking for something that wont take much "space" in the living room, my GF wont allow me for that.
And then the Harman Kardon looks like an good sollution thats small and fancy and delivers good sound?
snakzz is offline
post #5 of 18 Old 06-13-2013, 05:23 AM
eljaycanuck's Avatar
Quoted: 1341 Post(s)
Liked: 1955
... I'm basically looking for 2.1 home theater system. ... I plan to provide up to 1200 dollars ... I am looking for something that wont take much "space" in the living room ...
- Marantz NR1403 receiver ($400, shipped, at Crutchfield.com, Amazon.com, etc.)
- Cambridge Audio S30 speakers ($220/pr., shipped, at Crutchfield.com)
- SVS SB-1000 subwoofer ($499, shipped)
Total: $1,119
eljaycanuck is offline
post #6 of 18 Old 06-13-2013, 05:50 AM - Thread Starter
snakzz's Avatar
Total: $1,119
Hmm, dont think much of that is aviable here in norway :S
And would also like the set to include an blueray-player.
snakzz is offline
post #7 of 18 Old 06-17-2013, 01:48 AM - Thread Starter
snakzz's Avatar
snakzz is offline
post #8 of 18 Old 06-17-2013, 04:30 AM
Transmaniacon's Avatar
Quoted: 1581 Post(s)
Liked: 1381
You could look at the Cambridge Audio Minx speaker line, they are compact satellites that seem to offer good performance relative to their size. NHT also makes a number of smaller speakers and they are a very popular choice. Don't buy one of those HTIB setups, you will be wasting your money.
Another option is to wall-mount your speakers, they won't take up any space and might let you get something better than a satellite system.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #9 of 18 Old 06-17-2013, 05:48 AM - Thread Starter
snakzz's Avatar
Are the HTIB setups that bad?
snakzz is offline
post #10 of 18 Old 06-17-2013, 05:54 AM
Liked: 1381
Some of them sound okay, but for the most part they don't offer the capabilities of a more traditional speaker system, and their value is generally bad. And a lot of times they aren't easy to upgrade, meaning you have to start all over if you want something more.
post #11 of 18 Old 06-17-2013, 06:04 AM - Thread Starter
snakzz's Avatar
I just want to get an easy start and something that sounds, looks and are good.
I am not that experienced, and many of the sollutions that have been talked about here in the forums aint aviable here in Norway lol.
snakzz is offline
post #12 of 18 Old 06-17-2013, 06:09 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
HTIB is more of a of format for packaging equipment then it is an actual kind of equipment.
However, HTIB packages tend to minimalistic and stripped back, so their performance is typically more limited.
For example, the AVRs in HTIB packages tend to be light in terms of inputs. They may have non-standard output terminals. They often have a power amp for the subwoofer built-in, rather than the more typical practice of putting the power amp for the subwoofer in the subwoofer. The HTIB AVR then may not have a llne output for the subwoofer. Or none of these shortcuts may have been taken. You have carefully examine each one and see how its upgrade path winds around.
arnyk is offline
post #13 of 18 Old 06-17-2013, 06:19 AM - Thread Starter
snakzz's Avatar
This is what I have been looking at:
http://uk.harmankardon.com/bds-470-10217/bds-470.html
Is that the case in that sollution to?
I see that the set have alot of good reveiws.
snakzz is offline
post #14 of 18 Old 06-18-2013, 02:52 AM - Thread Starter
snakzz's Avatar
Anyone?
snakzz is offline
post #15 of 18 Old 06-18-2013, 04:22 AM
Liked: 1381
You could try posting in the HTIB Forum, you are not likely to get many recommendations for package systems like that here.
post #16 of 18 Old 06-18-2013, 04:24 AM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
Unfortunately, you said your budget is $1200 US currency but then everything you linked is in Norwegian currency or British pounds.
Really difficult to shop for you as we don't know what's available in Norway.
There is a European audio site that might be a little more helpful for you called AVForums.com
http://www.avforums.com/forums/audio-electronics/
Hope this helps.
Afro GT
afrogt is online now
post #17 of 18 Old 06-18-2013, 05:59 AM
Elihawk's Avatar
Liked: 1144
Elihawk is offline
post #18 of 18 Old 06-18-2013, 06:19 AM - Thread Starter
snakzz's Avatar
Originally Posted by Elihawk View Post
Sadly :\
snakzz is offline
Reply Speakers
