Which 3.1 wall-mounted or shallow floor-standing around $1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-16-2013, 08:23 PM - Thread Starter
sumik's Avatar
Our room is 11' wide and 15' long, with hardwood, 55'' TV will be mounted on the wall around 12' in front of us and I either want to hang some shallower speakers on the wall, or get shallower floor-standing ones.
It will be for movies mostly and I like smooth, softer sound, nothing too harsh and crisp.
Right now I have Polk RM6750 in my room and they're great, but it's in a bedroom.
I'd love to have speakers that are no more than around 6'' deep, the TV will be recessed into a wall a little bit, so a deep speakers will look really awkward.
They will be running off Denon AVR-1712
sumik is offline
post #2 of 5 Old 06-16-2013, 09:13 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
With those requirements it really sounds like you'll need wall mounts. Since you like your Polks, there's the OWM5.
crn3371 is offline
post #3 of 5 Old 06-16-2013, 09:31 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
In-wall could work in that space as well. There are some very shallow floor-standing speakers (mirage comes to mind), but I do agree on/in-wall may serve what you are looking for best.
lespurgeon is offline
post #4 of 5 Old 06-16-2013, 10:09 PM - Thread Starter
sumik's Avatar
I think it would be better for on-walls since they would flow better with the design.
I'm looking quickly at few manufacturers and I came across Paradigm Cinema line, the look is precisely what I need, but other than the look I know nothing about them smile.gif
Will need to grab a cup of coffe tomorrow and read about them on avs.
sumik is offline
post #5 of 5 Old 06-16-2013, 10:44 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
probably decent - Paradigms tend to be OK
look at KEF T-series
Definitive Technology Mythos is worth checking.
Reply Speakers
