Klipsch Synergy S-10 Thoughts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-18-2013, 03:43 PM - Thread Starter
Beeman82's Avatar
I've been looking for a pair of rear channel speakers for a few weeks (they're the last bit I need to finish my 5.1 setup.
Does anyone have any experience with the Klipsch Synergy S-10? Newegg just put them on sale for $120 which fits perfectly into my sub $200 for the pair budget.
I'm currently using A Polk CS2 center, Polk Monitor 60s as my front left and right and a BIC F12 subwoofer. I want to be sure that this will all fit together and sound nice.
ANY thoughts at all would be welcome, especially if you have any experience with these speakers.
Beeman82 is offline
post #2 of 6 Old 06-18-2013, 05:52 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 972
Those Klipsch horn tweeters will be a little brighter than your Polks but otherwise it should be fine.
Have you also considered Polk OWM3's which can be wall mounted too?
http://www.amazon.com/electronics/dp/B0018QNYVM
Afro GT
afrogt is offline
post #3 of 6 Old 06-18-2013, 06:20 PM - Thread Starter
Beeman82's Avatar
The reason the Klipsch speakers were appealing ot me is that they aren't so one directional. I figured that would help for less than perfect speaker placement?
Beeman82 is offline
post #4 of 6 Old 06-19-2013, 09:12 AM - Thread Starter
Beeman82's Avatar
I'm not sure if these funciton similar to a bipole speaker or not.. Any insight?
Beeman82 is offline
post #5 of 6 Old 06-20-2013, 09:52 AM
mbuck's Avatar
Quoted: 28 Post(s)
How does the Klipsch S-10 pair match up to the RB-52 pair?
I have 12x19 room that will be used mostly for movies and video games.
I'll be running either the RB-52s or RF-52 for the front, likely the RW12D for subwoofer.
mbuck is offline
post #6 of 6 Old 10-23-2013, 11:41 AM
fwh27713's Avatar
Has anyone compared S-10 and S-20?
fwh27713 is offline
Reply Speakers
Klipsch Synergy S 10 Premium Wdst Surround Speakers Pair
