Marine speakers in bathroom - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-19-2013, 11:50 AM - Thread Starter
Leisgean's Avatar
I want to put some in-wall speakers in my bathroom and run the wires to my onkyo ds484 receiver in the next room. Money is an issue and, through my searching, found my best bet would probably be to get some cheap marine speakers, they look to run 15-75 for a pair. Problem is every marine speaker I've found (mainly looking on amazon) is 4ohms and my receiver says 6 ohms min./speaker. Will marine speakers be ok or will they kill my onkyo? Or do I have a better option?
Leisgean is offline
post #2 of 4 Old 06-19-2013, 01:44 PM
walterappleby's Avatar
Quoted: 26 Post(s)
Liked: 77
Do they have to be inwall?
These are cheap and 8ohms.
http://www.monoprice.com/products/subdepartment.asp?c_id=109&cp_id=10904#1090405
NOTE: I haven't used them personally so you probably still have some research/homework to do... but I thought I'd give you some options to get you going.
walterappleby is offline
post #3 of 4 Old 06-19-2013, 03:34 PM
Speedskater's Avatar
Quoted: 38 Post(s)
Liked: 30
I doubt that you will play bathroom speaker very loud. The amp should be fine.
Leisgean likes this.
Kevin
Speedskater is offline
post #4 of 4 Old 06-19-2013, 09:28 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
I doubt you need marine - just polly-plas, not paper or silk.
lespurgeon is offline
Reply Speakers
