Klipsch Reference or Synergy for a small room? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-20-2013, 12:41 AM - Thread Starter
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
Hi guys.
I have a small 5 by 5 meter listening area where I have a klipsch Quintet 5 with sub. For movies its more than enough, but for music its lacking.
Thats why I thought rhat considering the size and price an f-20 or f-30 synergy based system would be more than enough for music.
Now I can also get an rf42 system for a just a bit more. But on the other hand Im thinking that the bigger cones of the f-20 or f30 would be better than the rf-42.
Option 3 would be to save up for a rf52 rf-62 but would it make sense for such a small space? And the price would go up significantly. Just dont want to over spend for such a small area. But the emphasis is on music. Just also noticed that the recommended rs-52 are huge which would also look weird innsuch a small space.
So basically I have a 5by5 meter area for movies/music in an appartment and have a 5007 marantz receiver. Should the f-20/30 be enough or an rf-42? Would an even high rf-52/62make any sense?
Sent from Samsung Galaxy Note II
blue13x is offline
post #2 of 16 Old 06-20-2013, 04:23 AM
Transmaniacon's Avatar
Quoted: 1582 Post(s)
Liked: 1381
How about going with the reference series bookshelves instead? You could get the RB-51 and RC-52, matched with a good sub it will sound just as good at the larger towers. The Klipsch reference series is much better than the Synergy line, I would definitely wait and save up for that. With the money saved from going with bookshelves instead, put that towards a better sub.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #3 of 16 Old 06-20-2013, 04:42 AM - Thread Starter
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
Hi thanks.
Im aware that the rf is more detailed.
But detailed enough to notice in a small listening area?
blue13x is offline
post #4 of 16 Old 06-20-2013, 04:55 AM
Shady195's Avatar
Liked: 34
If your not a complete audiohpile I'd get the synergy F-30's
A friend of mine has a complete F-30 setup and I must say it sounds pretty good. I personally don't like Klipsh due to the horn style tweeter, not going to go into to much detail aside from that but his F-30's have quite a lot of bass, i was actually quite impresed. They sound clear, have a lot of detail and can get quite loud with no distortion (I have personally witnessed him crank them up almost all the way and had his Denon reciever shut down before they ever broke up LOL)
I have also heart the RF-52 or 62, to be honest I don't recall which one it was..
Spent a littel bit of time with them when I was speaker shopping. Now granted i did not hear them Side by side for an A-B comparasion.. but I hardly could pick out a difference. I would say maybe the reference is a bit cleaner sounding.. based on that even myself if I wanted to save some cash I'd just get teh F-30's.. I think you'd be quite happy saving the cash and getting the F-30's.. they are great sounding speakers my own dislikes of the horn tweeter aside. They are clear, get loud and so long as you have a semi-decent reciever they won't distort on you.
I personally don't think there was a distinct enough difference to warrant the extra money but thats just me.
EMP E55ti | EMP E56ci | Polk T15's for surround duty | Ultimax 15" Sub | Integra 40.2 | Rotel 976 | Panasonic 60ST60
Shady195 is offline
post #5 of 16 Old 06-20-2013, 04:56 AM
Liked: 1381
Room size has nothing to do with speaker clarity, and honestly, a 15'x15' room isn't all that small. Bookshelves + sub offer great value. I would say get the reference bookshelves versus the synergy towers, use the extra money to get a better sub.
post #6 of 16 Old 06-20-2013, 05:50 AM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 567
The Synergy line is the cheapest they make and it sounds like it; not good.
I suggest that you read the article in the current Stereophile magazine regarding the Pioneer BS-22 speakers.
They are incredibly good-sounding speakers for a price that is amazingly low.
You can buy four of the BS-22 speakers at Amazon for only $220 TOTAL and the CS-22 center speaker for around $150.
The article compared these speakers with some very good ones that cost 3 TIMES as much, and they sounded nearly as good.
They should be perfect for your situation, and a sound a LOT better than any Klipsch speakers you can buy for under $800.
commsysman is offline
post #7 of 16 Old 06-20-2013, 05:56 AM
Liked: 1381
There is a thread in here where a guy was comparing the Pioneers to the Klipsch Reference series and ended up going with the Klipsch. They are two totally different sounds, so make sure you listen first (Best Buy carries both I believe).
post #8 of 16 Old 06-20-2013, 06:20 AM
Shady195's Avatar
Liked: 34
I apolgoize my friend has the Icons KF-28 not the Synergys..
I cannot comment on the Synergys as I have not heard them
However my statement still rings true in regards to the Icons.
Shady195 is offline
post #9 of 16 Old 06-20-2013, 06:36 AM - Thread Starter
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
You pretty much said what I was thinking. It seems everybody is quick to tell you to buy the Reference line. But I have a feeling that the difference is minimal and only when you have very good DVD-Audio recordings.
blue13x is offline
post #10 of 16 Old 06-20-2013, 06:39 AM - Thread Starter
blue13x's Avatar
Quoted: 52 Post(s)
Liked: 38
That's the other option I thought about. But a good quality reference bookshelf requires HUGE rears and an expensive center. In that case its almost better to go full tower.
blue13x is offline
post #11 of 16 Old 06-20-2013, 06:40 AM
Shady195's Avatar
Liked: 34
Keep in mind my post above.. I was incorrect as it was the Icons my friend has that I've listened to not the SYnergys.
I don't think the price difference between them is that much these days though
Shady195 is offline
post #12 of 16 Old 06-20-2013, 08:12 AM
Mike Garrett's Avatar
Quoted: 6699 Post(s)
Liked: 4387
The Reference line uses lighter stiffer cones and more powerful motors, compared to the Synergy line. For the small price difference, I would go with the Reference line.
mjgarrett100@gmail.com
Mike Garrett is online now
post #13 of 16 Old 06-20-2013, 08:25 AM
Liked: 1381
I am not sure what you mean by this? You would use the same center with either bookshelves or towers, and the surround speakers are irrelevant. The reference towers will play lower, but if you have a sub and a crossover set, the lower extension of the towers becomes wasted.
You can get the Reference bookshelf system for about the same price as the Synergies, and it will sound better.
post #14 of 16 Old 06-20-2013, 08:29 AM
flickhtguru's Avatar
Liked: 111
Hi guys.
You may want to look into the BIC America Formula Series speakers or the BIC Acoustech Platinum Series speakers. They sound great for the price and are way cheaper than the Klipsch. acousticsounddesign.com has great deals on them.
Shawn
flickhtguru is offline
post #15 of 16 Old 12-07-2013, 05:15 AM
Robbiey60's Avatar
Quoted: 450 Post(s)
Liked: 552
Hi guys.
Get the best you can possibly afford. If you can only afford synergy get the f30. Really good speaker for everything. If you go reference get at least rf62ii, the others are too small compared to the f30. I own f30 and rf82ii. The reference are better, but the synergy arent far behind(for these 2 floorstanders only) I started with f30 as mains, then upgraded to 82ii.
(2)RF-83 (1)RC-64ii (2)RF-82ii (2)RC-62ii
(2)Exodus audio tempest-x 15" subs in 200l sealed enclosures
Onkyo 705 pre/pro and rear surrounds
DSPeaker Antimode 8033 sub eq Behringer EP4000 subs
NAD C275BEE mains
AMC 2N100-3 surrounds and center
Robbiey60 is offline
post #16 of 16 Old 12-07-2013, 08:02 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
The thread dates from last June. The OP must have bought his speakers by now!
He has RF82II and RC-62 II as front three:
Robbiey60 likes this.
psgcdn is offline
Reply Speakers
