Klipsch RC-62ii amping? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-20-2013, 08:14 PM - Thread Starter
avthokie's Avatar
With my Denon 3312ci @125 watts per channel, will the rc-62ii at 150 rms function properly? I am investigating external amping, but don't want to get anything without knowing.
Denon AVR 3312ci--Samsung pn51e7000--Klipsch RC-62 II--2 Klipsch RF-82 II--Polk fxi-a4 surrounds--Panasonic DMP-BDT300--Xbox 360--PS3--Scientific Atlanta Explorer 8300HDC with TWC--2 Dayton sub 1200's
avthokie is offline
post #2 of 3 Old 06-20-2013, 08:25 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
The numbers need not match. You will probably turn the volume down before you need more power. A significant increase in sound pressure level is 3dB, it takes generally twice as much power to do that. Your Klipsch speakers are fairly high sensitivity (saw an unreferenced spec of 97dB) so you'd likely be at extremely high spl's before you'd need more power but you can do your own calculations with something like this http://myhometheater.homestead.com/splcalculator.html
lovinthehd is offline
post #3 of 3 Old 06-20-2013, 09:29 PM - Thread Starter
avthokie's Avatar
Thanks a lot. I hope to get all reference speakers soon. Just starting with the center for now.
avthokie is offline
Reply Speakers
Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Black Each , Klipsch Rc 62 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch R 5650 W In Wall System Rc 62ii Center , Klipsch R 5800 W In Wall System Rc 62ii Center Free Sub
