Energy Set Up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-20-2013, 08:19 PM - Thread Starter
Caco980's Avatar
Hi, I'm very new at Home theater audio. I started with an H/K 135 AVR with a Yamaha NX 220 set, I know now that this set up was not awesome but it worked for me for a year. Four months ago I upgraded to a Denon 2112 and a set of Definitive Tech Pro Cinema 60 plus added a Pro Sub 600 to the set up, and I still know that this is not very good but at the moment I thought it was good. My living room is 12' x 12' and know I'm thinking of upgrading to another of speakers.
Choice 1-fronts energy cb 10, center energy cc10 and rears energy cb 5
Choice 2-fronts and rears energy cb 5 and energy cc 5 center
Choice 3- fronts and rears energy cb 10 and energy cc10
All the set ups with a Velodyne VX 10
I watch movies and also play music on my AVR and I use multi channel for music.
Can anybody help me out and suggest which of these set ups would be best?
Caco980 is offline
post #2 of 5 Old 06-20-2013, 10:09 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
How bout Choice 4?
Energy CB-20 fronts, CC-10 center and CB-5 surrounds.
I think the CB-20 is substantially better than the CB-10 as a main speaker.
Afro GT
afrogt is offline
post #3 of 5 Old 06-20-2013, 10:29 PM - Thread Starter
Caco980's Avatar
My only concern on choice 4 would be if e cc10 is going to match or handle the cb20 when playing movies and are the cb 5 going to match them as we'll when playing music on all four channels?
Caco980 is offline
post #4 of 5 Old 06-20-2013, 10:34 PM
afrogt's Avatar
Liked: 755
The CC-10 goes well with the CB-10, CB-20, CF-30, CF-50 and CF-70.
If you want larger surrounds then get CB-10s back there instead of CB-5.
If music is a priority then you definitely don't want choice 2.
Afro GT
afrogt is offline
post #5 of 5 Old 06-20-2013, 10:41 PM - Thread Starter
Caco980's Avatar
Thanks, it's getting clear now. I'm going to try cb 20 fronts, cb 10 rears and cc 10 center.
Caco980 is offline
Reply Speakers
