Wireless / Bluetooth Speakers for patio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-20-2013, 07:49 PM - Thread Starter
SAgosto's Avatar
I am looking for a wireless / bluetooth speakers for my patio. The patio is 29' X 10' and it does have a power outlet. I have a Denon AVR2112CI in the main living room and I would prefer to use Zone 2 as I would have access to the cable box, HTPC, and AirPlay. Unfortunately, there is no LOS to the patio but I do have another cheapo Panasonic receiver (SAHE-100) in the 2nd living room that does have LOS to the patio but it doesn't have a 2nd zone. Sound quality isn't that important as long as I can hear it clear on the deck.
Does anyone have any ideas? I haven't found much while browing the web.
SAgosto is offline
post #2 of 2 Old 06-21-2013, 06:33 AM - Thread Starter
SAgosto's Avatar
http://www.outdoorspeakerdepot.com/wireless-rock-speakers-5inch.html
Looks like that will work. However, a rock on the patio might look weird? Either way, it seems to solve the problem. Not sure how their more expensive wireless speakers compare.
SAgosto is offline
Reply Speakers
