Which Speaker wire to buy? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 06-21-2013, 07:43 AM - Thread Starter
sid369's Avatar
Quoted: 43 Post(s)
I found someone who will help put the wires, but I need to order the speaker wires today.
Can anyone suggest what brand or wires should I buy. I will most likely use Amazon as it will ship the fastest.
Talking to the contractor he said to get 250ft.
sid369 is offline
post #2 of 21 Old 06-21-2013, 08:11 AM
Bill Fitzmaurice's Avatar
Liked: 4704
First you use this:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
and then you use this:
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10239
Bill Fitzmaurice is online now
post #3 of 21 Old 06-21-2013, 08:13 AM
Shady195's Avatar
Liked: 34
^^ What he said, if anyone tells you otherwise tell them to piss off..
While im sure there is such thing as horrible speaker cable.. The monoprice stuff is great and most other generic speaker wire is just as good
EMP E55ti | EMP E56ci | Polk T15's for surround duty | Ultimax 15" Sub | Integra 40.2 | Rotel 976 | Panasonic 60ST60
Shady195 is offline
post #4 of 21 Old 06-21-2013, 09:52 AM - Thread Starter
sid369's Avatar
Quoted: 43 Post(s)
Thanks for the links, but I need something from Amazon, so I can have it shipped early.
Any suggestions from amazon
sid369 is offline
post #5 of 21 Old 06-21-2013, 09:56 AM
Liked: 4704
If you need it that fast drive to the nearest Lowes or HD. Copper is copper.
REDdawn6 likes this.
post #6 of 21 Old 06-21-2013, 09:57 AM
KidHorn's Avatar
Quoted: 1380 Post(s)
Liked: 889
Is the wire going to be run in wall or outside the walls? Does it need to be flat? How long is the longest single run? Will it be run outside? Do you care about the color?
KidHorn is offline
post #7 of 21 Old 06-21-2013, 10:00 AM
holt7153's Avatar
Quoted: 137 Post(s)
Liked: 221
You can buy Monoprice via Amazon.
http://www.amazon.com/s/ref=nb_sb_noss?url=srs%3D2529935011%26search-alias%3Dspecialty-aps&field-keywords=250ft&rh=i%3Aspecialty-aps%2Ck%3A250ft
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #8 of 21 Old 06-21-2013, 10:02 AM
KidHorn's Avatar
Liked: 889
KidHorn is offline
post #9 of 21 Old 06-21-2013, 10:05 AM
Otto Pylot's Avatar
Quoted: 1371 Post(s)
Liked: 857
Agreed. I just used 16AWG, 2-wire ribbed that I bought for about $0.16 per foot at the local hardware store. It was heater cord wire.
Otto Pylot is offline
post #10 of 21 Old 06-21-2013, 10:29 AM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
+1. Go to your nearest hardware store if you need it fast.
crn3371 is offline
post #11 of 21 Old 06-21-2013, 01:24 PM - Thread Starter
sid369's Avatar
Quoted: 43 Post(s)
http://www.amazon.com/Monoprice-100-Feet-High-Purity-Oxygen-Free-Speaker/dp/B001UNLRGC/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1371842349&sr=1-1&keywords=monoprice
The wires will go inside the wall, are there separate wires for inside wall vs. running outside
I need it by Tuesday next week.
sid369 is offline
post #12 of 21 Old 06-21-2013, 02:38 PM
BobL's Avatar
Liked: 56
In wall wires use in wall rated wire like this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2816&seq=1&format=2
Do not use this:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2747&seq=1&format=2
If it is going to be run in the ground or outside and not just attached to the side of the house you should use direct burial cable like this:
http://www.parts-express.com/pe/showdetl.cfm?partnumber=102-1072
There is no difference in performance except that the in wall and direct burial wire is twisted and would be less prone to act like an antenna and pick up interference (at short distance probably not a big deal).  However there is a difference to insurance agents if you have a fire and don't have wire rated to code.  If the fire is related to your AV equipment they refuse to pay the claim.  I have seen this happen personally.  An elderly man had wired 8 pairs of speakers to his very modest Sony stereo receiver without an impedance matching circuit.  His receiver caught fire and burned up there living room.  Insurance company refused to pay the claim because it wasn't the proper wire, even though the wire had nothing to do with the cause of the fire.
For not much more money use the wire that you are supposed to for the intended use.
BobL is offline
post #13 of 21 Old 06-21-2013, 03:44 PM
Jben04's Avatar
Quoted: 51 Post(s)
Earlier i was i the same boat after ordering my new energy take classics,,,i ended up going with a monoprice brand,ordered from amazon,,picked up 14 gauge, 100 ft for 30 dlvd,,and being delivered on monday ( only ordered today) biggrin.gifhttp://www.amazon.com/gp/product/B001UNLRGC/ref=oh_details_o00_s00_i00?ie=UTF8&psc=1
LG 47LW5600 (3D) - Energy take classic 5.0 - SVS PB-1000 - Panasonic BDT220 (3D) - Sony BD S350 - Insignia NS BRDVD4 (Region Free) -
Denon AVR X2100W - Harmony One Remote - Harmony Ultimate One.
Jben04 is offline
post #14 of 21 Old 06-22-2013, 02:33 PM
blklightning's Avatar
Quoted: 12 Post(s)
Liked: 64
If the wires aren't platinum with gold flaky bits in them, it's gonna sound like crap. You don't want to go to Monoprice.com. Don't do that. They try to sell you things that work great for very little money. No. Platinum or bust.
500 gigs FTL.
blklightning is offline
post #15 of 21 Old 06-22-2013, 04:28 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
^A wise guy, eh???
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #16 of 21 Old 06-22-2013, 09:02 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
so which wire is better than monoprice?
caloyzki is offline
post #17 of 21 Old 06-22-2013, 09:05 PM
Liked: 4704
None. Claims of magical improvements in sound by using expensive wire are pure unadulterated hogwash.
post #18 of 21 Old 06-22-2013, 09:12 PM
eljaycanuck's Avatar
Quoted: 1240 Post(s)
Liked: 1814
This: Oracle V1.3 Bi-wire Speaker Cable
eljaycanuck is offline
post #19 of 21 Old 06-22-2013, 09:16 PM
caloyzki's Avatar
Quoted: 168 Post(s)
Liked: 46
lol 8feet for 40.hell no. so why that guy is complaining about monoprice is not good? i guess he don't know what he is talking about? im using monoprice wire for all of my speakers and the sound is wonderful.
caloyzki is offline
post #20 of 21 Old 06-22-2013, 09:18 PM
Liked: 1814
Who, blklightning? It looks to me like he was just being sarcastic.
post #21 of 21 Old 06-23-2013, 08:40 AM
Geoff4RFC's Avatar
Quoted: 319 Post(s)
Liked: 1574
Awesome calculator, thanks for that.
Of course he was, those are my kind of lines biggrin.gif It takes one to know one cool.gif
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
Reply Speakers
