Best 2.1 CPU Speaker System Under $150??? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 06-24-2013, 11:30 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
Stick with the Klipsch 2.1 system then. It is a good performer for the money, and should work well for you. I however would recommend getting a DAC (Digital to Analog Converter), to filter out interference from your PC. The Behringer UCA202 is a good choice, you plug it in via USB, and then connect it to your speakers via RCA. http://www.bhphotovideo.com/bnh/controller/home?O=&sku=422094&Q=&is=REG&A=details Also, www.monoprice.com is a great place to get cables and not have to overpay.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #32 of 37 Old 06-24-2013, 11:48 AM - Thread Starter
cjp3's Avatar
Quoted: 35 Post(s)
cel4145,
I have a polk PSW303 Sub i was trying to sell (its part of my old home theater)
can i use that sub with the Emotiva - airmotiv 4 for my home office?
and if so how would i connect everything?
cjp3 is offline
post #33 of 37 Old 06-24-2013, 12:32 PM
cel4145's Avatar
Quoted: 2668 Post(s)
Liked: 3002
Yes. It would work fine with the airmotivs. You would have to split the 2 channel output from your computer and run it to both the airmotivs and the sub.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | HE-400i | NAD HP50 | Sony MDR-1A | Soundmagic E50 & E80 | X5ii | DX50 | E12
cel4145 is offline
post #34 of 37 Old 06-25-2013, 04:36 AM - Thread Starter
cjp3's Avatar
Quoted: 35 Post(s)
hey guys thanks for all the input. i think ive decided to buy a pair of self powered speakers & add a sub later on rather then waste my money on a crappy 2.1 multimedia setup.
i came across a pair of Audioengine A5+ for $320 how do they compare to the Airmotiv 4's
audioengine also has the 8" sub i could always add down the rd
cjp3 is offline
post #35 of 37 Old 06-27-2013, 12:34 PM - Thread Starter
cjp3's Avatar
Quoted: 35 Post(s)
how are the Audioengine A5+ any good??
cjp3 is offline
post #36 of 37 Old 06-28-2013, 04:41 AM
Liked: 1394
Yeah they are great speakers, can't go wrong either way.
post #37 of 37 Old 06-30-2013, 03:42 PM - Thread Starter
cjp3's Avatar
Quoted: 35 Post(s)
think im gonna go with the audioengine 5+ for $330 cause they have a larger woofer which should be better for bass until i add a sub if i choose to & the 5+ speakers are prewired to add a sub.
cjp3 is offline
Reply Speakers
