BUDGET SPEAKERS - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-27-2013, 08:06 AM - Thread Starter
harman208's Avatar
HI GUYS I AM FROM INDIA (Ludhiana) I HAVE DENON 1713 . & SONY ACTIVE SUBWOOFER 160 W
I AM LOOKING FOR BUDGET SPEAKERS SET (ONLY 5 SPEAKERS) - MY PREFERENCE 60% MOVIES / 40 % MUSIC
BUDGET FOR SPEAKERS BELOW 40K INR
OPTION 1 - JAMO 426 HC3 (5 SPEAKERS) -Available for 21.8k at REL. Digital chandigarh (not available in my city, so difficult to carry from there)
OPTION 2 - MAGNAT SUPREME 800 (tower) +Magnat Monitor Supreme 100(surround) + Magnat - Supreme Center 250(total costing me 32k)
OPTION 3 Jamo 416 (available Iin my city at 30k)
Q1.Have any one auditioned any of these sets .
Q2 Do you recommend any other option
Q3 Will my sony Sub can perform good with these or should i buy new sub-woofer (not enough budget)
Q4 what about service/ Warranty as i am in ludhiana ; all are having service center in delhi only i think .
PLEASE REPLY ASAP
harman208 is offline
post #2 of 16 Old 06-27-2013, 11:00 AM - Thread Starter
harman208's Avatar
AND ALSO PLEASE SUGGEST WEATHER I SHOULD GO FOR SATELLITE SPEAKERS + SUBWOOFER /OR STICK TO TOWER SPEAKERS SET WITH OLD SUB
post #3 of 16 Old 06-27-2013, 12:39 PM
Tappits's Avatar
40,000.00 INR = 664.500 USD
Tappits is offline
post #4 of 16 Old 06-27-2013, 08:40 PM - Thread Starter
harman208's Avatar
Yes you can say approx 650-700$
post #5 of 16 Old 06-27-2013, 10:50 PM
NuSoardGraphite's Avatar
Quoted: 326 Post(s)
Liked: 298
That's actually a decent amount to spend on budget speakers. However if you want to buy a full 5.0 speaker set, then that doesn't leave you with very much left over for a decent Sub. If your Sony sub works okay, keep it for now and upgrade it later when you get a chance.
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #6 of 16 Old 06-28-2013, 01:38 AM - Thread Starter
harman208's Avatar
BUT please suggest which one option to consider
post #7 of 16 Old 06-28-2013, 01:50 AM
Quoted: 326 Post(s)
Liked: 298
Front speakers: Polk TSi400 http://www.crutchfield.com/p_107TSI400B/Polk-Audio-TSi400-Black.html
Center speaker: Polk TSi CS10 http://www.crutchfield.com/p_107CS10B/Polk-Audio-TSi-CS10-Black.html
Surround Speakers: Polk TSi100 http://www.crutchfield.com/p_107TSI100B/Polk-Audio-TSi100-Black.html
All together around $660.
Also that Jamo set you mentioned would work. Don't know how good they are, but it is an inexpensive set.
Also, this is what I use:
Sony SS-B3000: http://www.amazon.com/Sony-SS-B3000-Bookshelf-Speakers-Black/dp/B000OG6I6A/ref=sr_1_1?ie=UTF8&qid=1372406061&sr=8-1&keywords=SS-B3000
Center speakers: Sony SS-CN5000: http://www.frys.com/product/6173009
Surround speakers: Sony SS-B1000: http://www.amazon.com/Sony-SS-B1000-2-Way-Bookshelf-Speakers-SONSSB1000/dp/B0057WOVN8/ref=sr_1_4?s=electronics&ie=UTF8&qid=1372406187&sr=1-4&keywords=SS-B1000
All together cost me about $240. May cost you more than that now because the price seems to be going up on these speakers. Also the CN5000 is discontinued by Sony and becoming hard to find. They may be making way for a new version. These speakers are not the best, but they are very affordable and they sound pretty good when set up correctly.
post #8 of 16 Old 06-28-2013, 02:08 AM - Thread Starter
harman208's Avatar
Thanks for your reply , have you auditioned polk audio / magnat monitor speakers. how thy sound..?
post #9 of 16 Old 06-29-2013, 06:41 AM - Thread Starter
harman208's Avatar
Please some good suggestions are welcomed
post #10 of 16 Old 06-29-2013, 06:48 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The Pioneer BS-22 speakers are WAY WAY better than the Sony speakers you have, and the price is ridiculously low (around $150 per pair) for their quality.
If you can, look at the review of them in the current Stereophile magazine.
I would buy 4 of those and their matching center speaker to start with.
commsysman is offline
post #11 of 16 Old 06-29-2013, 07:29 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
the most common recommended budget speakers are the infinity primus series, polk monitor series and the andrew jones pioneers. All have their fans, and all have their good points and bad points, and all can be had for ridiculously low prices....at least in the USA.... i like the polks my self and think the pioneers are the worst of the 3 with the infinities being in the middle.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #12 of 16 Old 06-29-2013, 08:46 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
PLEASE REPLY ASAP
Can you forget you know how to use the All Caps button? LOL
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #13 of 16 Old 06-30-2013, 09:52 PM
Quoted: 326 Post(s)
Liked: 298
Don't let Commsysman hear you say that! He always recommends the Pionneers for a budget setup.
(I need to hear these speakers. Haven't had a chance to yet. I think the Pioneer's are ugly as sin and I don't think I could get them past the WAF. I've heard the Polk speakers and don't think they sound all that much better than my signficantly cheaper Sony speakers. Though I'm finding that with all these budget speaker brands, they all tend to sound similar)
post #14 of 16 Old 10-15-2016, 03:30 PM
Liked: 0
HI GUYS I AM FROM INDIA (Ludhiana) I HAVE DENON 1713 . &amp; SONY ACTIVE SUBWOOFER 160 W<br>
I AM LOOKING FOR BUDGET SPEAKERS SET (ONLY 5 SPEAKERS) - MY PREFERENCE 60% MOVIES / 40 % MUSIC<br>
BUDGET FOR SPEAKERS BELOW 40K INR<br>
OPTION 1 - JAMO 426 HC3 (5 SPEAKERS) -Available for 21.8k at REL. Digital chandigarh (not available in my city, so difficult to carry from there)<br>
OPTION 2 - MAGNAT SUPREME 800 (tower) +Magnat Monitor Supreme 100(surround) + Magnat - Supreme Center 250(total costing me 32k)<br>
OPTION 3 Jamo 416 (available Iin my city at 30k)<br>
Q1.Have any one auditioned any of these sets .<br>
Q2 Do you recommend any other option<br>
Q3 Will my sony Sub can perform good with these or should i buy new sub-woofer (not enough budget)<br>
Q4 what about service/ Warranty as i am in ludhiana ; all are having service center in delhi only i think .<br><br>
PLEASE REPLY ASAP
hi harman from where do you purchase if you want to go with option 2.
dhir81 is offline
post #15 of 16 Old 10-15-2016, 03:36 PM
Quoted: 693 Post(s)
Liked: 549
Three year old thread. You may have a better chance getting a response by starting a new thread.
Just sayin.
Kef Q100 FL/FR, Kef Q200c center, JBL Loft 40 surrounds , JBL SP 150 & Bic F12 subs, Denon AVR710Ws, , Panasonic 50" Plasma, Samsung cable box, Xbox One, Toshiba laptop.
Bedroom: JBL Loft 50 FL/FR , Loft 20 center, JBLSP 150 sub, Pioneer VSX-830K, PS3, 32" Insigna LED.
pase22 is offline
post #16 of 16 Old 10-15-2016, 10:54 PM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
If you can get a local demo, see if you can listen to Q Acoustics. Well reviewed speakers, based in Europe. Get the front pair (3020 or 3010 L&R), and add a center (3090), then find some really cheap speakers for the surround, and use the sub you already have.
RayGuy is offline
Reply Speakers
