In Wall Speaker for 5.1 HT (Advice Needed) ~ $1000 - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Which speakers would you choose (x5)?
Paradigm AMS250 0 0%
Speakercraft LCR 3 AIM 0 0%
Definitive Tech UIW 55/65 0 0%
Other 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Old 06-28-2013, 12:14 PM - Thread Starter
skagen's Avatar
I'm a total audio noob and would like some advice on speaker selection. The setup will mostly be used for Movies + Games + TV
I have a HT room 20' deep x 14.5' wide. I was planning on running a 5.1 set up. Here's what I have so far:
AV Receiver: Denon AVR AX4000
Sub: Episode 300W12" Sub
That leaves the in wall speakers. I wanna run a LCR and 2 rears.
I was hoping to spend < $1000 for 5 in wall speakers. Which do you guys recommend.
Current considerations:
Paradigm AMS 250 ($220 each) x 5
SpeakerCraft LCR 3 ($190-$220)
Definitive Technology UIW 55 or 65 ($179 - $259)
If you guys have any others that i should consider that's best bang for the buck, I'd love to hear your reccomendations. Help this noob out to make a good one and done purchase. I don't really have an option to "add on", so i'll have to try and get this right in one shot.
Thanks in advance!
skagen is offline
Old 06-28-2013, 12:31 PM
mattm06's Avatar
I just purchased these:
I used them for my rear surrounds and my L and R speakers
. I used this for my center: http://www.crutchfield.com/p_107MC85/Polk-Audio-MC85.html
I have a Denon 2113 powering them and I am very pleased with them.
mattm06 is offline
