Connecting speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 06-28-2013, 12:29 PM - Thread Starter
Jammers10's Avatar
I've been stripping cable for my speakers without any tools and wonder what are the best ones to buy. It's been a bitch doing it the hard way with a not so sharp knife. I am also going to get a better gauge of speaker wire and banana plugs. It's taken too long connecting all the speakers the way i've been doing it. Are banana plugs the way to go?
Jammers10 is offline
post #2 of 13 Old 06-28-2013, 01:28 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
http://www.monoprice.com/products/product.asp?c_id=105&cp_id=10509&cs_id=1050903&p_id=3354&seq=1&format=2
That tool works great if you're stripping a bunch of speaker wire but it takes too long to adjust to cut a couple wires. I'd rather use a box cutter to strip a few cables. Banana Plugs look nice and are easily removed, how often do you disconnect your speakers? I have banana plugs on the receiver and bare wire on the speakers. If I ever have to do a little clean up, its easier to unplug from the receiver using banana plugs.
Mrkazador is offline
post #3 of 13 Old 06-28-2013, 01:56 PM - Thread Starter
Jammers10's Avatar
I've heard that using banana plugs makes one more connection separating the wire from the amplifier. Does that make any difference in sound or connection?
post #4 of 13 Old 06-28-2013, 02:04 PM
eljaycanuck's Avatar
Quoted: 1235 Post(s)
Liked: 1808
For cutting and stripping wire, I find that a pair of pliers with sharp cutting blades work just fine.
+1 to banana plugs. They don't affect the sound, and once you've put them on, disconnecting / re-connecting wires to your AVR or speakers will never be a chore.
eljaycanuck is offline
post #5 of 13 Old 06-28-2013, 02:19 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
As long as its a solid connection, there will be no difference in sound.
post #6 of 13 Old 06-28-2013, 05:37 PM - Thread Starter
Jammers10's Avatar
I know banana plugs connect to the back of the A/V receiver's binding posts but do they also connect to the speakers connectors too?
post #7 of 13 Old 06-28-2013, 05:53 PM
Mrkazador's Avatar
Quoted: 253 Post(s)
Liked: 378
They can, just make sure it accepts them.
post #8 of 13 Old 06-28-2013, 07:58 PM
Liked: 1808
All but the cheapest speakers should have binding posts that accept banana plugs. If they don't accept banana plugs, try speaker pins (such as these) instead.
post #9 of 13 Old 06-29-2013, 05:22 AM
Nethawk's Avatar
Liked: 118
I use a bic lighter smile.gif Burn around the wire about an inch from the end, wet your fingers and pull. Works like a charm, it's fast and no chance of cutting into the wire.
IMO your best connection will always be with bare wire into the binding post. I use banana plugs from my wall jacks, but where convenience dictates it's always a bare wire connection. SpeakON connectors are another highly regarded option but I've never used them.
Nethawk is offline
post #10 of 13 Old 06-29-2013, 03:26 PM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Agreed.
And a wire cutter/stripper is only about $10 or so from the local hardware store. Better investment than banana plugs unless the goal is to plug and unplug the speakers frequently.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #11 of 13 Old 06-29-2013, 07:55 PM
Prime316's Avatar
Quoted: 179 Post(s)
Liked: 204
I find that the space on back of receivers is at a premium. Even very large ones like the one I own. Now that I've started using banana plugs, I would never be without them.
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 2
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #12 of 13 Old 06-30-2013, 01:09 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
]I just use a pair of dykes, cut part of the way through the jacket and pull. Banana plugs make things easy peazy, lemon squeezy!
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #13 of 13 Old 06-30-2013, 02:35 PM
afrogt's Avatar
Quoted: 1057 Post(s)
Liked: 758
I found this exact tool in a local store for under $5. Very quick and easy to use. Been using it for 3-4 years now.
http://www.ebay.com/itm/WIRE-Stripper-Stripping-TOOL-Automatic-Self-Adjusting-/290925088564?pt=LH_DefaultDomain_0&hash=item43bc7c8f34
Afro GT
afrogt is offline
Reply Speakers
