Help picking an amp to go with JBL Loft 40 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-29-2013, 01:09 AM - Thread Starter
dreadful's Avatar
Today I bought the JBL Loft 40's since they were on sell at Fry's for $57 to use at my desktop for music and gaming. Now I'm looking for an amp to go with them. And I was thinking of picking up the LP-2020A+, but I'm not sure if it's powerful enough. And I'm hoping someone can tell me.
Loft 40 TECHNICAL SPECIFICATIONS
Low-frequency transducer: 130mm (5-1/4") PolyPlas cone
High-frequency transducer: 25mm (1") soft dome on EOS waveguide
Power handling: 10 – 125 watts
Frequency response: 55Hz – 20kHz
Nominal impedance: 8 ohms
Sensitivity (2.83V/1m): 90dB
Enclosure type: Ported
Connector type: Binding post
Dimensions (H x W x D): 252mm x 156mm x 191mm (10" x 6-1/2" x 7-1/2")
Weight: 2.4kg (5.3 lb) each
Model Name: LP2020A+
Frequency Range (Hz): 20Hz - 20kHz
Out Power: 2*20W
Item Size: 12*14.7*4.2MM
Item Weight: 0.3 kg
Input power: 12V 6A DC
Input sensitivity: 200mv
Speaker impedance: 4 - 8ohm
Input impedance : 47k
Signal noise / ratio : >100db
Minimum THD : <0.05%
dreadful is offline
post #2 of 6 Old 06-29-2013, 03:20 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
how loudly do you plan to play them? I use the LP 2020A+ with a pair of speakers that have a lower sensitivity than your JBL's and it plays louder than I could ever want.
you're not sitting far away since they are computer speakers. You should be just fine with that amp.
Afro GT
afrogt is offline
post #3 of 6 Old 06-29-2013, 03:41 AM - Thread Starter
dreadful's Avatar
I probably just play them at average listening levels every now and them I might play them a little louder, and thanks for the reply.
dreadful is offline
post #4 of 6 Old 06-29-2013, 06:33 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The Onkyo TX-8255 receiver is only $140 from Amazon.
That might be a good possibility.
commsysman is offline
post #5 of 6 Old 06-29-2013, 03:52 PM - Thread Starter
dreadful's Avatar
That ones too big for my desk thanks though.
dreadful is offline
post #6 of 6 Old 02-07-2014, 08:44 AM
das323's Avatar
Hi
Old thread, I know,but I'm wondering if you can share your experience with the Loft 40s.  What do you think?  There's a great deal on 'em now, and I'm considering them for music listening, off a t-amp Topping TP20, in a small room.  I can't find any decent reviews, and there is no stock near me for a test listen.
Any feedback will be most appreciated.
das323 is offline
Reply Speakers
