To upgrade or not to upgrade... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-29-2013, 08:20 AM - Thread Starter
hsumix's Avatar
I currently own Paradigm Studio 60 v5. Love them. However, thru my local shop, I may have the chance to do the 1 yr upgrade to the Studio 100 v5 for a little bit of extra coin. My dilemma is tho, that I'm not 100% sure that it's worth the extra coin. Basically, my question is, should I just put my $$ towards a PrePro/amp for the 60's or upgrade to the 100's and do the PrePro/amp in another year or two? I use them mostly for music and my room is 18x11. Any thoughts or advice would be greatly appreciated.
hsumix is offline
post #2 of 3 Old 06-29-2013, 01:53 PM
Petden's Avatar
Liked: 33
Judging by your name I assume you have a sub. How well is it integrated into your system? Going to larger speaker only gives you more bass. If I had the option I would consider upgrading to the S2.
Now if you don't have a sub then the added bass from the 100's might be worth the price.
Petden is offline
post #3 of 3 Old 06-29-2013, 03:20 PM
cel4145's Avatar
Quoted: 2658 Post(s)
Liked: 2990
Or, depending upon the type of music, a sub might be better. For EDM, hip hop, rap, and other bass heavy genres, a sub might give you more of that room filling tactile feeling in the low bass.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Reply Speakers
