I'm looking for a decent speaker stand that are about 36 inch tall that can support weight up to 20 lbs or 25 lbs..can someone help me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 06-29-2013, 03:36 PM - Thread Starter
Mangorush XIII's Avatar
Hi, guys. I'm new to the forum and need help finding a decent or a good 36 inch speaker stand that can support weight up to 20-25 lbs but I have no idea where to look or what are good brands that I'm looking for and hope I could get help here. So if anyone could help me out, I'd really appreciate it, if there is anything I have left out or you need to know, please let me know..hope you guys can help me out, I'd appreciate it.
Mangorush XIII is offline
post #2 of 16 Old 06-29-2013, 03:41 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Take a look at Sanus.
crn3371 is offline
post #3 of 16 Old 06-29-2013, 03:45 PM - Thread Starter
Well, I have looked at them but I am not sure which ones are quality stands which is what I am asking for help on.
post #4 of 16 Old 06-29-2013, 05:32 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
The hard part is being able to find one that tall tha can handle that much weight. Most stands for bookshelf speakers are around 24".
crn3371 is offline
post #5 of 16 Old 06-29-2013, 05:49 PM
Chevypower's Avatar
Liked: 40
Chevypower is offline
post #6 of 16 Old 06-29-2013, 06:15 PM - Thread Starter
I see, is that what the majority uses is 24 inch speaker stands?
post #7 of 16 Old 06-29-2013, 06:15 PM - Thread Starter
Hmm, I may look into that, seems to be decent, I may to do more research on it but thanks anyways.
post #8 of 16 Old 06-29-2013, 06:51 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
bladerunner6 is offline
post #9 of 16 Old 06-29-2013, 07:05 PM
wlhungdude's Avatar
Quoted: 180 Post(s)
Liked: 223
Hi Mango,
I use and would recommend the Sanus SF (steel) stands as well. I use the 26" ones, as that is what puts my speakers' tweeters at ear level. They are very sturdy, and heavy. I filled mine with (very dry) play sand, and the extra weight makes them even more stable. The use of 'sticky-tack' is also recommended, and shouldn't damage the finish on your speakers.
Hope it helps,
Joseph
mods, can we have a 'dislike' button ?
wlhungdude is online now
post #10 of 16 Old 07-02-2013, 11:09 AM - Thread Starter
Originally Posted by wlhungdude View Post
Hi Mango,
Hope it helps,
Joseph
Hi and thanks, I will check it out but one more question if you guys don't mind me asking, I have two front speakers that are a little taller than my rear speakers, is it okay to use the same speaker stands for those as well or would I need a different one to match the height of my rear speakers or it doesn't really matter?
post #11 of 16 Old 07-02-2013, 11:26 AM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
For your front speakers, you want the tweeters at ear level. For the surounds, I've heard anywhere from ear level, to 2-3 feet above ear level.
crn3371 is offline
post #12 of 16 Old 07-02-2013, 07:35 PM
Quoted: 911 Post(s)
Liked: 489
VTI has a few 36" stands. I've put ~45lb speakers on the DF36 model and it was fine. (I did add kitty litter to the post.) I've never tried their others in that size, but I think they have a couple styles. (I also use their BLE101 adjustable stand for my surrounds, but it's IMO not suitable for a 20+ lb speaker.)
If you want wood rather than metal, I think Wood Technology also makes a couple in that size. I've only used their "furniture grade hardwood" center-channel stand, but it was fine for the price.
Fit and finish isn't superior, but better than one finds in the similarly-priced English-made stands (Target, Apollo, etc.). Can't compare to Sanus, Bell'O, etc, because I've not really used their stands.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #13 of 16 Old 07-03-2013, 12:49 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3032 Post(s)
Liked: 2964
I'm using a 30" tall Sanus Steel Series stand, and it is bombproof - very sturdy !
http://www.sanus.com/ca/en/products/speaker-foundations/sp-steel
AV Science sells them BTW.
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is online now
post #14 of 16 Old 07-04-2013, 01:48 PM - Thread Starter
So far so good, thank you all for the big help but if I could ask for recommendation should I go with the 30 inch or 34 inch stands? This will be in the living room by the way and I wonder if 34 will look a little better than 30 inch? Any opinions on that?
post #15 of 16 Old 07-05-2013, 02:45 PM
Home Theater Lover
Craig Peer's Avatar
Liked: 2964
Well, I believe that you want the speakers tweeter about ear height, so you might need to measure your speakers and seating. I went with 30" myself.
FYI - I also used " Earthquake Putty " to attach my bookshelf speakers to the stands ( since my speakers do not have an attachment point on the bottom ). It works great ! smile.gif
post #16 of 16 Old 07-05-2013, 03:01 PM
enricoclaudio's Avatar
Quoted: 1100 Post(s)
Liked: 1127
I have Sanus NF36C (36" tall) for my rears. They look pretty good, though.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Reply Speakers
