Can someone help identify this speaker and tweeter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 06-30-2013, 04:35 PM - Thread Starter
Wake4real's Avatar
I bought these without knowing much. The cabinets and stand alone are worth a great deal more than I paid, custom built (I believe) solid wood. I can't get the speaker out to check and I don't want to damage anything. Without looking at the back can anyone identify? (Long shot I know).... The side of the front says "SR 115/1."
Here's a pic
Wake4real is offline
post #2 of 2 Old 07-01-2013, 06:53 AM
HOTDIGITY's Avatar
Quoted: 114 Post(s)
Liked: 89
Have you attempted to remove the tweeter? It should be pretty easy to do. Just remove the 5 outer screws, put your hand over the faceplate, point the baffle to the floor and if it does not drop out on its own, tap the back of the cabinet with your other hand and it should pop out.
Can't tell what brand/model it is by looking at it.
HOTDIGITY is offline
Reply Speakers
