Polk Speaker Suggestions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 07-01-2013, 09:42 AM - Thread Starter
eshaheen's Avatar
A friend of mine has a Polk soundbar which I was super impressed in regards to the sound quality. It sold me on the brand, so I want to do Polk speakers in our new space. I am looking at the followings options - would appreciate feedback from people that own these or know a lot about them!
Front R/L
Polk Audio TSi400 Floorstanding Speaker
Center Channel
Polk Audio CS10 Center Channel Speaker
Subwoofer
Polk Audio Monitor Series PSW10 10-Inch Powered Subwoofer
Polk Audio PSW125 12-Inch Powered Subwoofer
Rear R/L
Polk Audio OWM3 On-Wall Speaker
eshaheen is offline
post #2 of 20 Old 07-01-2013, 03:42 PM
m_vanmeter's Avatar
If I may, a couple of suggestions about your Polk setup. I have Polk Monitor 70 towers (equivalent to TSI500 or Monitor 75T) and the CS2 center (equivalent to the CS20 or 25C). The are fine speakers, very dynamic and clear....and for the money - excellent speakers.
The entire Monitor series ( Monitor - old and new, Monitor II, and TSi are functionally equivalent). The TSi400 = Monitor 60 = Monitor 65T, the main difference is who sells them and the price.
I strongly recommend you check our www.newegg.com and sign up for their "e-Blast" sales newsletter to catch very good sales on the Polk "new" Monitor "T" series. Shipping is usually included in the sales price (a very big deal for heavy speakers)
As to the subwoofer, I recommend the PSW505 12" powered subwoofer at the starting point for your consideration. The units you mentioned are made to a price point and I'm afraid they tend to sound like it.
http://www.newegg.com/Home-Audio-Speakers/BrandSubCat/ID-12345-494
IF you have room, I'd recommend the larger CS20 (CS2 or 25C in the other Monitor series) center channel. The center speaker carries almost all of the spoken audio and a very high percentage of the effects audio that is centered on the screen action - it should be as capable as you can make it.
m_vanmeter is offline
post #3 of 20 Old 07-01-2013, 03:55 PM - Thread Starter
eshaheen's Avatar
Thanks for the input m_vanmeter. Why would Polk make it so confusing to have 3 of the same speakers? Or are you just saying that they may look different - but the stuff that matters is the same?
I definitely have room for a larger center channel, so I will look at upgrading that one from what I originally was looking at. Same for the sub.
I chose the TSi400 for the front surrounds are a medium between the 300 and 500. Do you have any experience with the 400 to compare it to the 500?
eshaheen is offline
post #4 of 20 Old 07-01-2013, 08:00 PM
oleon621's Avatar
Quoted: 28 Post(s)
Liked: 29
I don't know if you already made your purchase but I would strongly recommend you forego the TSI series and move up to the RTI series if possible. Especially if your speakers are for home theater use. The sound for me personally is night and day. Try Polk Ebay.....the TSI series is ok but if you don't want that itch to upgrade get the RTI line. As far as a SUB goes looki outside of Polk. They're not known for making Subs. Try SVS or HSU. The Polk PSW505 is an ok sub considering it could be had for 180..so in that sense its no so bad.
Speakers (L/R,C,Surrounds)B&W CM6 S2, Polk RTI CSI5, and Polk RTI6.
Sub-SVS SB 2000 & SVS PB10-NSD
Receiver-Yamaha Aventage RX-A2000
Amp-Adcom GFA 5500
oleon621 is offline
post #5 of 20 Old 07-02-2013, 09:32 AM
m_vanmeter's Avatar
I really think the different Monitor series have more to do with distribution channels (and specific pricing within each). The latest series, the "T" series like the Monitor 65T towers and 25C center are the "newest" in the line of Monitor speakers and do exhibit a change in speaker layout and possibly the crossover electronics. I do not have any experience with the TSi400 (Monitor 60, Monitor 65T)....just the 70 series.
As to the above comment on the RTi series...I agree IF you have the budget. The Polk Monitors and TSi series are a hell-of-a buy when on sale and you will have to spend considerably more to get a noticeable upgrade in sound.
The Polk store on eBay is "Polk Audio Direct" and the seller name is "polkaudio". I have purchased from the store and was very satisfied with the speaker I received. Please, DO NOT fall into the trap of buying speakers from any random seller on eBay - only deal with the authorized Polk Audio Store to insure the quality and warranty of the product you receive. Be careful of shipping costs as well - speakers are heavy.
post #6 of 20 Old 07-02-2013, 09:48 AM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Agreed. And probably being able to raise the price, too. Seems like the Polk Monitor T series has been a little more expensive at Newegg than the Polk Monitor IIs.
This comparison of Polk Monitor II 70s and Polk Monitor 75Ts may help to understand better what is going on:
http://www.avsforum.com/t/1456569/polk-monitor-75t-vs-polk-monitor-70-series-ii-review-comparison
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #7 of 20 Old 07-02-2013, 09:54 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
The CS10 is their cheapest center speaker and sounds like it.
It will not match up that well with the other speakers. The CSiA4 would be a much better choice.
Those subwoofers are not what you want. They are inadequate. I suggest that you get either the Polk PSW505 or the Klipsch RW-12D.
commsysman is offline
post #8 of 20 Old 07-02-2013, 10:10 AM - Thread Starter
eshaheen's Avatar
Nothing has been purchased yet. Got a few months to figure out exactly what I want. I understand there is always going to be something better, but it also always comes at a cost. I guess I'm more curious to see what peoples opinions are of the class speakers I outlined then committing to spending even more. I'll look into the sub recommendations - thanks!
eshaheen is offline
post #9 of 20 Old 07-02-2013, 10:12 AM - Thread Starter
eshaheen's Avatar
I will definitely look into the eBay store route. Amazon also has really good warehouse deals on returns - which I have used for all kinds of stuff and it is always a good deal. They also have a great return policy if you are unhappy.
eshaheen is offline
post #10 of 20 Old 07-02-2013, 10:13 AM - Thread Starter
eshaheen's Avatar
Great - thanks!
eshaheen is offline
post #11 of 20 Old 07-02-2013, 10:21 AM
cel4145's Avatar
Liked: 2987
The CSiA4 is not a proper match for the Polk Monitor II, Polk Monitor T, or TSi series. It's the matching center to go with the Polk RTiA series.
However, it would be best to get the Polk CS20 or the Monitor 25C. These are the better grade of center channels to match those speakers.
cel4145 is offline
post #12 of 20 Old 07-02-2013, 12:22 PM - Thread Starter
eshaheen's Avatar
Any thoughts on these surround speakers:
It sounds like for the front channels I am best waiting for a good deal to come up on the Polk Monitor II 70s and Polk Monitor 75Ts. Center channel the consensus looks to be the CS20, CSiA4 or the Monitor 25C. Polk has a couple of subs that are decent, but I guess I may be better off looking at a different brand to get the best in this range.
eshaheen is offline
post #13 of 20 Old 07-02-2013, 04:58 PM
cel4145's Avatar
Liked: 2987
No. The CSiA4 is probably NOT the best center channel choice. Your center channel should timbre match the left and right speaker for an optimal front soundstage. That means either (a) using the exact same speaker as the center as the left and right (which is optimal) or (b) getting the center channel from the manufactured made to match in the same series. Even though the CSiA4 is a better grade of center channel because it's from a higher model series, it could easily be a poor timbre match.
But you can double check by asking in the Polk owners thread on AVS. They can also advise you regarding the on-wall speakers: http://www.avsforum.com/t/618137/calling-all-polkies-official-polk-thread
cel4145 is offline
post #14 of 20 Old 07-02-2013, 05:32 PM
oleon621's Avatar
Quoted: 28 Post(s)
Liked: 29
Polk Audio OWM3 On-Wall Speaker for rears shouldn't be a problem. The front stage is priority since they do all the work and you want the front stage timbre matched as mentioned above. CS20 is probably your best choice. I use TSI400 for surrounds and my front stage speakers are the RTI series. At some point I will get the matching surrounds though. So you could just get TSI100s. Up to you.
Good luck
Amp-Adcom GFA 5500
oleon621 is offline
post #15 of 20 Old 07-02-2013, 06:24 PM - Thread Starter
eshaheen's Avatar
Appreciate the info - makes sense.
eshaheen is offline
post #16 of 20 Old 07-02-2013, 06:29 PM - Thread Starter
eshaheen's Avatar
Good luck
I have tons of space in the front for whatever size speakers, but my surround space is more limited (open floor plan with lots of windows). I'd love to have floor standings for surround as well, but it probably will not work out. My only real decision to make in regards to surround is 5.1 vs 7.1. I've had 7.1 for a few years now and like having the best (yes, I know - there are now even better configurations), but I really wonder if it is worth it. Most of what I watch (antenna, AppleTV, Netflix) is 5.1. The occasional blue ray comes along with 7.1 and its always cool, but I feel like most of the "neatness" is just in my head and not any audible difference... Don't won't to stray from the original topic as I can imagine there are tons of opinions on this, but thought I would throw it out there in case anyone has any feedback with what I am trying to do here.
Thanks for all the input everyone!
eshaheen is offline
post #17 of 20 Old 07-04-2013, 01:00 PM - Thread Starter
eshaheen's Avatar
After looking at the Polk eBay store (which has great prices), I'm contemplating the RTi10 fronts, CSi5 and still the OWM-3 surrounds. My question now is if I need a sub right off the bat (I've read that these speakers deliver a lot of bass on their own). Also, I don't want to spend more than $500 on a receiver to adequately power these - is that possible, and if so, what recommendations do people have?
eshaheen is offline
post #18 of 20 Old 07-04-2013, 08:50 PM
Lance-AR's Avatar
My understanding in trying to plan out my own open floor plan is that it will take some serious subs, near field placement or a combination of both. I would go ahead and plan on putting whatever you get directly behind or beside your seating position.
Lance-AR is offline
post #19 of 20 Old 07-17-2013, 02:03 PM
oleon621's Avatar
Quoted: 28 Post(s)
Liked: 29
I would recommend you find a receiver that has pre outs so that in the future your able to add amplification and adequately power those RTI10's. A receiver @500 won't do them justice. Now if you start looking at Yamaha Aventage, Pioneer Elite SC, and Denon 33XX, then you at least know your getting some good juice out of them to power your speakers. As far as a sub goes, I recommend HSU, SVS, Epik, or Outlaw. SVS has some really good subs for 499.99. Good luck.
Amp-Adcom GFA 5500
oleon621 is offline
post #20 of 20 Old 07-17-2013, 02:10 PM - Thread Starter
eshaheen's Avatar
Hey - thanks for the reply. I actually settled on a little different setup after some help from the Polk thread. This is what I plan on going with for those interested:
Front
Polk RTi8
Center
Polk CSi5
Surround
Polk RTiA1
Sub
Outlaw Audio LFM-1
Receiver
Pioneer SC-1222-K (with intentions of adding an amp down the road - but the D3 should keep me happy for a while)
eshaheen is offline
Reply Speakers
