Speaker setup for 240 sq ft ( 12 X 20 ) - 9ft height theater room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 07-01-2013, 11:28 AM - Thread Starter
drvgames's Avatar
Hi Experts,
Please help me in setting up a good home theater with dimensions 240 sq ft ( 12 X 20 ) - 9ft height basement room.
Currently I got Denon AVR2313CI Receiver, and have no clue on what to get next (speakers ? , projector ? etc ..)
Speaker budget: $1500 to $2000
Need something good for Movies , sports.
drvgames is offline
post #2 of 19 Old 07-01-2013, 02:00 PM
m_vanmeter's Avatar
Hello, welcome to the forum...
What equipment do you have now ? What specifically do you want your budget to cover ?
m_vanmeter is offline
post #3 of 19 Old 07-01-2013, 04:50 PM - Thread Starter
drvgames's Avatar
I only got Denon AVR2313CI Receiver.
I want to get all speakers with sub woofer for around $1500 (Max $2000)
and a projector and projector screen for around $2000 (flexible if any better option)
and I am not sure what else I would need to complete my home theater. Please advice.
This is my first time trying to set up a dedicated home theater room, please help !
drvgames is offline
post #4 of 19 Old 07-01-2013, 07:45 PM
Elihawk's Avatar
Quoted: 1313 Post(s)
Liked: 1144
1500 dollar budget would give you 500 for a good sub and 1000 for speakers.
A couple options:
Ascend acoustic cmt340s front stage...
EMPtek tower fronts...
The svs pb1000 is probably the best sub around 500.
Set up #1: EMP e5Ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, SVS NSD SB12 sub, Marantz Slimeline 1504 AV receiver
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and EMPtek10i10i sub, Denon 1910 AV receiver
Set up #3: Philharmonics- BMR in a 2.0 system, music only, Yamaha RXV-363 AV receiver
Elihawk is offline
post #5 of 19 Old 07-01-2013, 09:56 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1995
The HSU hybrid 3 with the 5.1 would be a great setup, it comes with a good sub in the VTF-3 MK4 and you could add a second set of surrounds down the road for only $320.
jbrown15 is offline
post #6 of 19 Old 07-01-2013, 10:54 PM
Nethawk's Avatar
Liked: 119
Another option within your budget is the highly regarded Kef Q series - Q500 towers or Q300 bookshelf, Q200C and Q100 surrounds. I would personally go with the Q700 towers and postpone purchase of surrounds when budget allows.
Nethawk is offline
post #7 of 19 Old 07-02-2013, 03:06 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
Another possibility is some Infinity Primus speakers with a Powersound sub.
bladerunner6 is offline
post #8 of 19 Old 07-02-2013, 08:50 AM - Thread Starter
drvgames's Avatar
Thanks guys for great info, looks like lot of options, not easy to decide rolleyes.gif
drvgames is offline
post #9 of 19 Old 07-02-2013, 08:54 PM - Thread Starter
drvgames's Avatar
Here is what someone from Paul's TV suggested me, please check and let me know ...
Front speakers (x2):
http://www.paulstv.com/Speakers/Definitive-Technology-BP6B.asp
These are listed at $399 each, but I can actually do 2-for-1, so they would be $199.99 each
Rear and surround speakers (x4):
http://www.paulstv.com/Speakers/Definitive-Technology-ProMonitor-800.asp
Center speaker(x1):
http://www.paulstv.com/Speakers/Definitive-Technology-ProCenter-1000.asp
Subwoofer:
http://www.paulstv.com/Speakers/Definitive-Technology-SuperCube-2000.asp
drvgames is offline
post #10 of 19 Old 07-04-2013, 05:28 AM - Thread Starter
drvgames's Avatar
Can anyone please comment if they used these Def Tech. speakers and how good are they compared to other recommendations, please help me choose my first home theater setup ..
drvgames is offline
post #11 of 19 Old 07-04-2013, 06:13 AM
swallan's Avatar
Quoted: 12 Post(s)
Liked: 27
we had the sm350s and the clr 2002 for our center for years was very happy with the sound, looks like the system you are looking at is a step up from what I had it should make you very happy.
swallan is online now
post #12 of 19 Old 07-04-2013, 06:28 AM
afrogt's Avatar
Quoted: 1335 Post(s)
Liked: 923
I wouldn't get the Def Tech sub. The SVS PB-1000 or Rhythmik LV12 would be better if you've got $500-$600 for a sub.
http://www.svsound.com/subwoofers/ported-box/pb-1000#.UdV3HvnVB8E
http://www.rythmikaudio.com/LV12R.html
Afro GT
afrogt is offline
post #13 of 19 Old 07-04-2013, 09:35 AM
swallan's Avatar
Quoted: 12 Post(s)
Liked: 27
I agree on the def tec sub we have the supercube two it is a nice sub but for the price I think I could do better.
post #14 of 19 Old 07-05-2013, 06:11 AM - Thread Starter
drvgames's Avatar
Thanks guys, as per feedback I got from you guys and the deal I am getting on Def Tech speakers, I would go with following, any more comments or suggestions welcome ....
SVS PB-1000 Sub
Center speaker(x1):
drvgames is offline
post #15 of 19 Old 07-05-2013, 09:55 AM
swallan's Avatar
Quoted: 12 Post(s)
Liked: 27
that should be a very nice system enjoy.
post #16 of 19 Old 07-18-2013, 11:22 AM - Thread Starter
drvgames's Avatar
Got my speakers, and also got Epson 5020ub. Now need projector screen.
What is the biggest screen size I can go for my room ( 12 ft wide, 20 ft length, 9 ft height) .
What screen (brand) model do you guys suggest ? Please help !
drvgames is offline
post #17 of 19 Old 07-18-2013, 11:39 AM
eljaycanuck's Avatar
Quoted: 1341 Post(s)
Liked: 1956
Use ProjectorCentral.com's Projection Calculator to determine what screen size will work for you.
Re. screens: There are a lot of choices, including Carada, Da-Lite, Draper, Elite, Grandview and Stewart.
My screen is a Grandview and I've been very happy with it. A quality product, reasonably- and competitively-priced. I would recommend Grandview.
eljaycanuck is offline
post #18 of 19 Old 07-19-2013, 06:48 AM - Thread Starter
drvgames's Avatar
After reading more about screens, I am looking for motorized, tab-tensioned screen(between 120 and 140 diag wide) and I think for epson 5020 with throw distance around 16.5 and my room (12' x 20') dedicated theater room(full dark with all dark colors), 1.1 gain should be enough.
Please suggest the best one without having to pay too much of price.
drvgames is offline
post #19 of 19 Old 07-20-2013, 03:19 PM
m_vanmeter's Avatar
with a very large screen, and with the center channel speaker you mentioned, you may want to consider an "acoustically transparent" screen so the center channel can sit behind the screen. The alternative would be down near the floor or up near the ceiling - neither an optimal location.
Reply Speakers
